Looking @ 94 855t With 107xxx Miles
6 replies to this topic
#1 brickhead
brickhead
  • 251 posts
  • Interests:My '94 945T and her '90 245 and our 00VR Dancehall Reggae from sound Systems like Stone Love and Kilamanjaro Sound from JA,The Far East Rulerz Mighty Crown, disco and house music, Afro cuban music, jazz.
Posted 19 March 2006 - 06:50 AM
Evening all.
Found a 95 855T for sale.owner is asking 4500. Hopefully i can take a look tomorrow. Rear engine seal leaks, a/c evap. hard to tell if it is working in the winter.How can check for that? Check Turbo oil retun line. Where is this line located? What else to look for?
Thanks for the help in identifying problem areas.
RED I
#2 Stamperman
Stamperman
  • 158 posts
Posted 19 March 2006 - 01:40 PM
QUOTE(brickhead @ Mar 19 2006, 06:50 AM) View Post
Evening all.
I have a 94 I bought with 115,000 miles and a bad rear main seal 2 years ago for $3200. The 94 should be fine. I think $4500 is too much with a bad seal. That's a $1200 repair at the dealer, and probably $900 to $1000 at an independant garage. One benifit of the 94 is the self diagnostic box. You don't need a code scanner to retreive the codes. You can look in bay repair maint section under ligths, 1993 to 1995 diagnostic connectors and see how to pull the codes. If you are going to look at the car I suggest you do this while looking at it.
My $02.
94 850 Turbo Wagon - Metallic Grey - MBC, SlammedHo Hoses & Fancy clamps, IPD block of urethane upper mount, standard K&N filter, added factory rear bar where there was none, super fancy E3 sparkplugs.
72 1800e - Real pretty, real slow. - rebuilding engine and adding Eaton M45 just for kicks.
#3 mbsl98
mbsl98
  • 697 posts
  • Interests:cars, boats, skiing, family, travel
Posted 19 March 2006 - 03:12 PM
You can check AC freon presure with a $10 guage. It snaps onto the AC fill connection just behind the right headlight (black 19mm nut has to be removed to open teh connector) - Start car and turn on AC for a couple of minutes, set on defrost so the compressor should engage even if moderately cold outside. Pressure running is about 45 pounds when really full with freon, and teh low pressure cut-off will turn off compressor under about 22 pounds.
'94 is a great year, really just missing the side air bags that were standard beginning on the '95 Turbo's.
Mike Sullivan
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
#4 bloc
bloc
  • 261 posts
Posted 19 March 2006 - 03:15 PM
also look up how to retrieve the actual mileage from the ecu.
as you may know, the odomoters frequenly break on these cars and there is a fair chance it has more than 115000 miles on it. potentially a lot more. sometimes they are repaired and not reset, just left to start going up from wherever they broke.
when i was looking at my 95 855 i noticed the odo was broken. after some prodding the PO said it had been broken for "about an oil change". i then pulled the number from the ecu and he was right.
almost forgot...
you cant check the return line directly without jacking up the car. usually though, if it's leaking badly there will be oil all over the back edge of the oil pan, which you should be able to see.
good luck
Justin
1995 855 T-5M
1998 Jetta TDI
www.savetheinternet.com
#5 brickhead
brickhead
  • 251 posts
Posted 20 March 2006 - 01:02 AM
Thanks for the response people.I talked to the owner today and it sounds real good! allwork has been done. PnP switch, A/C evap, blower motor, end link,motor mounts plus other things. still have to ask about the rear oil seal. Hopefully i'll be taking a look/drive this Wednesday.
RED I
#6 kenhoeve
kenhoeve
  • 2,617 posts
Posted 20 March 2006 - 03:54 AM
QUOTE(brickhead @ Mar 19 2006, 08:02 PM) View Post
94 is a great year. the rear main should come right off the price. i would also ask about brakes and suspension. chances are suspension is shot, even if it drives ok, and if the rotors are baked you are looking at some serious cash. make sure you pull the mileage from the diagnostic. 115k is super low for that year. I wouldn't hesitate to drive that car to 250k. I only drove mine to 215k. tongue.gif
2007 V70R
#7 Curtis G
Curtis G
  • 61 posts
Posted 20 March 2006 - 05:56 PM
I payed 2000$ for my 94 one year ago, it had 350kilometres on it, it's now at 424kms hasn't required anything but regular service and a vacume hose. Very tough Car!!!!
94 850 T5
