Do I Need New Engine Mounts?
9 replies to this topic
#1 hockeyboss77
hockeyboss77
  • 129 posts
  • Interests:1993 Volvo 850 GLT
Posted 19 March 2006 - 09:56 AM
I've begun to notice that my car is vibrating more. Especially when im at a stop in idle. The RPM's stay the same just below 1000, but it seems to vibrate more then it did when i got the car. When i drive the vibrations are very minimal. Ive got a 93 850 with approximately 185,000 miles on it. Would new Engine mounts sound like a solution to the problem?
Thanks in advance,
Bastiaan VandenBerg
1993 850 GLT N/A :(
#2 Slater
Slater
    Quickbrick Motorsports
  • 3,198 posts
Posted 19 March 2006 - 11:09 AM
QUOTE(hockeyboss77 @ Mar 19 2006, 04:56 AM) View Post
Thanks in advance,
Bastiaan VandenBerg
Yeah, you probably have no mounts left and it's metal on metal.
My guess is the firewall mount. When that goes it will cause a lot of vibration. The stock one is puny and tears easily. Volvo changed the mount later and the revised mount is 2x beefier than the early mount.
#3 hockeyboss77
hockeyboss77
  • 129 posts
Posted 19 March 2006 - 07:05 PM
Slater, your always a great help. Thankyou so much. Which engine mounts should i get? Arent there different materials to choose from? Would you suggest getting one from IPD?
Thanks A Lot!
1993 850 GLT N/A :(
#4 eldertec
eldertec
  • 187 posts
Posted 20 March 2006 - 12:25 AM
Is it a DIY job?
Cost to take in to Volver Dealer?
FCP?
Robert
1995 855 Turbo
IPB Image
#5 hockeyboss77
hockeyboss77
  • 129 posts
Posted 20 March 2006 - 12:39 AM
I'm going to do this job myself, and some help from my dad. IPD's engine stabalizer mount has directions and said can be installed with common hand tools i think. Not sure if i need to lift the engine, but that shouldnt be a problem for me.
1993 850 GLT N/A :(
#6 Slater
Slater
  • 3,198 posts
Posted 20 March 2006 - 03:20 AM
QUOTE(hockeyboss77 @ Mar 19 2006, 02:05 PM) View Post
Thanks A Lot!
Well, IPD makes a poly engine torque mount bushing. I make poly firewall and lower tranny torque mounts. Then the rest of the mounts (side mounts, subframe mounts, etc) are pretty much OEM rubber mounts only.
#7 BeachRat
BeachRat
    Team GKT
  • 2,761 posts
Posted 20 March 2006 - 05:09 AM
With that amount of mileage on a car that old, you might want to consider the lower mounts, as well.
It's a bracket that goes on the front of the motor (passenger side of car), and two hydraulic mounts on either side (intake and exhaust manifold sides).
FCP Motor Mounts
9135178 - Bracket
6801722 - Left Hydraulic Mount
9434435 - Right Hydraulic Mount
Total cost was about $150 for OEM mounts. Labor is a bit intense, I had professonal help. You need to lower the subframe while supporting the motor.
If you can get under the car, you'll see two round, cone-shaped rubber mounts (those are the hydraulic puppies) and a bracket if you remove the right front wheel. It's best to consult a local that knows Volvos, as the labor on this can be very costly. It can definitely be done in a garage with jackstands and a lift, but it would be a whole-day project.
If you need more help for the DIY, PM me.
Edited by BeachRat, 20 March 2006 - 05:14 AM.
#8 hockeyboss77
hockeyboss77
  • 129 posts
Posted 20 March 2006 - 06:24 AM
QUOTE(Slater @ Mar 19 2006, 07:20 PM) View Post
How would I order th mounts from you slater? Is there a specific website I can go to? I'm very interested.
By the way, I was able to look at the engine stabalizer mount (top of engine to firewall) and found it was completely shot. THe bushing is almost completely gone. Thanks for the help guys.
1993 850 GLT N/A :(
#9 hockeyboss77
hockeyboss77
  • 129 posts
Posted 20 March 2006 - 06:35 AM
QUOTE(BeachRat @ Mar 19 2006, 09:09 PM) View Post
FCP Motor Mounts
9135178 - Bracket
Thank you so much BeachRat, This diagram is going to help me out so much. I'll be sure to PM you if I have any questions.
1993 850 GLT N/A :(
#10 Slater
Slater
  • 3,198 posts
Posted 20 March 2006 - 12:36 PM
QUOTE(hockeyboss77 @ Mar 20 2006, 01:24 AM) View Post
I am finishing up the website as we speak.
