Noises
11 replies to this topic
#1 fixxer
fixxer
  • 5 posts
Posted 19 March 2006 - 03:27 PM
'97 850 sometimes when I put on the brakes the whole car starts shakeing and makes a vibrating noise
happens more often when more people are in the car
any clues?
#2 Volvo Virgin
Volvo Virgin
    Fadeproof Rob Rock
  • 2,080 posts
  • Interests:Old Corvettes / Muscle Cars-currently driving/restoring a 70 Corvette convertible 350 4spd<br /><br />Off-roading-'89 Chevy C/K 1500 Short-bed pickup.Mods completed so far- 3&quot; lift / 33'&quot; BFG All-Terrains / cat-back dual exhaust.Mods to come- body work and fresh paint / 71&quot; vette motor transplant / lots more goodies <br /><br />PWC-97 Sea Doo GTX<br /><br />Dirt Bikes-sold my 99 Yamaha 350 Warrior.Have not replaced it yet
Posted 19 March 2006 - 03:33 PM
Rob
99 S70
#3 bloc
bloc
  • 261 posts
Posted 19 March 2006 - 03:44 PM
anyone that suggests warped rotors as soon as they hear of these symptoms needs to read this article.
http://stoptech.com/tech_info/wp_warped_brakedisk.shtml
fixxer. how many miles on your car? any idea if it has the original brake discs?
can you get similar results by getting the car to 80 or so and really applying the brakes?
1995 855 T-5M
1998 Jetta TDI
www.savetheinternet.com
#4 fixxer
fixxer
  • 5 posts
Posted 19 March 2006 - 04:20 PM
it has about 70k miles, but the brakes are relatively new
ill try to go to 80 and put on the brakes hard
#5 Patrick.
Patrick.
  • 5,707 posts
Posted 19 March 2006 - 04:32 PM
okay-- sounds like discs w/ a TV (thickness variation) tongue.gif
I had this same issue, replaced my front rotors, and all was well.
#6 Volvo Virgin
Volvo Virgin
    Fadeproof Rob Rock
  • 2,080 posts
Posted 19 March 2006 - 06:37 PM
QUOTE(850Charisma @ Mar 19 2006, 11:32 AM) View Post
+1 Warped may be a misnomer,so if it pleases everyone we'll try and use thickness variation from now on.Or if that upsets anyone.......maybe we can use Excessive Runout. wink.gif Either way I think most realize when you have a pulse while applying your brakes,it is usually caused by a deviation in the thickness of your rotors.
Rob
99 S70
#7 bloc
bloc
  • 261 posts
Posted 20 March 2006 - 04:31 PM
if you want to know what is likely the real cause, read the article.
most of the time when people think rotors have excessive runout or a thickness variation, it is in fact uneven pad deposits on the surface of the rotors. these can be removed without machining or replacing the rotors.
1995 855 T-5M
1998 Jetta TDI
#8 Volvo Virgin
Volvo Virgin
    Fadeproof Rob Rock
  • 2,080 posts
Posted 20 March 2006 - 09:00 PM
QUOTE(bloc @ Mar 20 2006, 11:31 AM) View Post
For many years I worked in a shop where we machined rotors regularly.Over that period I machined more rotors than I could possibly count that miked so inconsistently that there was no possible way you could have sanded or grinded them effectively.And even if you had attempted this method by hand,there would be no possible way to attain a true flat braking surface,such as machining does.I can honestly say that the number of times I saw any signs of residual pad deposits were few and far between.That's not to say it never happens,and cetrtainly if it does it must be caught in the very early stages to be rectified by hand.I just don't happen to concur that more times than not the problem with a pulsing brake pedal is excessive pad deposits,and not an actual warped rotor,especially with the number of cheap import rotors flooding the market.Just my humble opinion. smile.gif
Edited by Volvo Virgin, 21 March 2006 - 01:11 AM.
Rob
99 S70
#9 fixxer
fixxer
  • 5 posts
Posted 20 March 2006 - 09:55 PM
are you sure it has nothing to do with the engine mounts because all of the shaking seems to be coming from the front end and only happens sometimes
#10 Volvo Virgin
Volvo Virgin
    Fadeproof Rob Rock
  • 2,080 posts
Posted 20 March 2006 - 11:45 PM
QUOTE(fixxer @ Mar 20 2006, 04:55 PM) View Post
Front end vibration would be indicative of front rotors if you can feel it in the steering wheel and brake pedal while braking.Motor mounts wouldn't be the first thing that comes to my mind,but they are easy to check,especially the top one in the back of the engine compartment,which is the most frequently broken mount.Pull the nut and bolt out and see if it is in one piece,or otherwise.Good luck.
Edited by Volvo Virgin, 21 March 2006 - 01:10 AM.
Rob
99 S70
#11 bloc
bloc
  • 261 posts
Posted 21 March 2006 - 06:44 AM
characteristics of broken motor mounts are usually excessive vibration upon acceleration, not braking. it is possible for mounts to be so blown that when you hit a big bump you will feel a thump as the engine flops around, but youd likely know long before it got that bad.
volvovirgin, i'm not talking about doing it by hand.
likelyhood of the car being on the original rotors is pretty high, and they are by no means cheap. they probably do need to be replaced anyway.
i'm not saying the rotors -ARENT- warped, just that pad deposits are the culprit in far more of the pulsation-on-brake-application cases than people realize.
stoptech's preferred method of getting rid of the deposits is to load the caliper with a set of very abrasive pads and go through a specific procedure of hard stops to scrub the rotors.
i really dont mean to sound like a hotdog, but read the article. even if you dont agree with me, there's easily enough good info on their tech section in the white papers about brake systems to make it worth your time.
1995 855 T-5M
1998 Jetta TDI
#12 Volvo Virgin
Volvo Virgin
    Fadeproof Rob Rock
  • 2,080 posts
Posted 21 March 2006 - 03:30 PM
QUOTE(bloc @ Mar 21 2006, 01:44 AM) View Post
Hey bloc,I'm all ears to different opinions and things I didn't know or consider before.That's why I did read the article initially,and what I found troubling was his statements that he never saw a warped rotor in all his years,which I thought was misleading due to the context.He was basing his article on his experience,which was 40 years of professional racing.I would assume he was using higher end products specifically for high performane/racing applications,and mostly in a racing arena which are definitely more abusive and much different conditions than the average passenger car ever sees,even with spirited driving.I would agree that smoking your pads early in their life cycle before breaking them in correctly could produce pad deposits and/or premature pad failure.It would also stand to reason that a higher end race-specific rotor would most likely be more resilient to warping,and given the constant attention that race cars are attended to,pads and rotors are constanly being checked and replaced before small problems become big problems.My experience is that most of the time in a passenger car application by the time the rotors are producing a pulsation while braking,unless caught very early if indeed an improperly broken in new set of pads and/or an excessive pad deposit situation,the rotors will be too far gone for a solution other than machining.This would also take into account the differences in the quality of the parts in the specific application.
Edited by Volvo Virgin, 21 March 2006 - 05:13 PM.
Rob
99 S70
