After The Leak.....
11 replies to this topic
#1 MVFDV50
MVFDV50
  • 2 posts
  • Interests:Volunteer Firefighter,Fire Lt., FF2, EMT-B
Posted 20 March 2006 - 03:38 AM
Have had my v70 GLT for a month now, finally got up the courage to look under the padding to see if it was leaking. Yup, soaked. Got core from FCP, stripped the seats, carpet, padding. cleaned as much as possible for a 25 degree day as I could stand. took it to my master volvo mech today. He popped out the core while I was doing plugs, rotor, cap, gas filter. The core was good! had a build date of 10/05 on it. Happy that I could use the $130 for other parts, but pissed that the padding was not addressed. mad.gif
So, the real point of this post is: what have you folks done to clean the front (both sides) AND rear pads?
The fronts are that thick rubber like material with dense foam bottom. It does not just hose out. How do you get the coolant out? ShopVac? Carpet machine ( rental ? rolleyes.gif )
And the back is soaked too! it looks like pressed clothe fiber. I would just trash it and replace with foil backed auto padding but there are the clips for the seat bolt covers. Do boneyards have these?
Thanks! (I searched but didn't find anything on this)
1st post!
2005 V50 2.4i white, bone stock, wife's ride
1998 V70 GLT Nautic Blue, stage zero, 108k
2003 Avalanche Z71, LPM, some mods...
#2 Guest_Guest_MVFDV50_*_*
Posted 23 March 2006 - 08:51 PM
I threw away the front foam pads and replaced with carpet backing with plastic sheet on one side.
Used spray adhesive to provide a little stick. I washed out the rear pad enough to re-use it.
Didn't want to go without the plastic covers on the seat bolts.
Total time to do 1.5 hours. Have to remove the front seats and back bottoms.
Next: dash indicator lights....
#3 Detailsetc.
Detailsetc.
  • 312 posts
Posted 23 March 2006 - 10:01 PM
QUOTE(Guest_MVFDV50_* @ Mar 23 2006, 03:51 PM) View Post
Try and lift the carpets out and let them dry . If you can put it in a garage and try leaving the heat on for awhile with the carpets lifted it should dry. Try sticking a bottle or somthing to keep the carpets up off the floor and it should be ok. The only problem is bacteria growing and causing your car to stink. Best bet is while the carpets are up is to spray some anti bacterial spray under them to stop them from smelling in the future.
06/S60R/Rica/Ferrita/ViVA Hybrid Turbo/Stage 2
98V70T5M WI/FMIC/HBEAM/RICA/FERRITA DP/IPD EXHAUST/CUSTOM19T/APEXI/BMC/MSD/PP R MANI/ADJ CAMS
06XC70
#4 MVFDV50
MVFDV50
  • 2 posts
Posted 24 March 2006 - 03:29 AM
Thanks for the reply. Whoever had this car must have just kept feeding coolant into it. I was able to hose out and dry the rear pad but the front padding doesn't dry out. It wouldn't vac out and won't hose out. My volvo tech says they cut out the front padding and order a dr. side replacement piece if it is warrenty work. They don't have the pass. side. I would say that they each had a quart of coolant in them. I am happy with the quick fix with padding from Lowe's.
#5 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 24 March 2006 - 04:07 AM
if the core you pulled was good, then where was the coolant leaking from and why was the carpet soaked?
#6 James A Sousa
James A Sousa
  • 307 posts
Posted 24 March 2006 - 12:01 PM
I have seen posts about leaks at the firewall connectors. Long-term leaks should show signs of dried residue from the coolant.
#7 thedriver
thedriver
  • 41 posts
Posted 24 March 2006 - 12:23 PM
In the past I have put a domestic dehumidifier in the car and shut the doors. Leave it over night or longer if necessary and the car will be bone dry and hopefully odour free.
Mark
97 850 R (Red)
02 V70 2.4T (Swapped for my Daughters 2000 S70 so she can carry our Grandchildren in even greater safety!!
2006 XC70 2.4D LE Silver
#8 Guest_Guest_*
Guest_Guest_*
Posted 24 March 2006 - 03:31 PM
I would have to park this thing in the sahara to dry out this much coolant.
I have pics with everything out of the interior and the puddles of green on the rear floorpans.
The stuff under the front pads was a light green paste. Like the goop my kids have.
There was evidence of collant leaks on the heater housing. They changed the core and didn't
clean anything! Still smell coolant, I may try to clean the vent pipes.
I drove the car without any pads or carpet for several days b4 determining the leak was corrected.
Did you ever hear the flow of coolant thru the core? I was surprised how loud it was. Heard every pebble
that hit the floorpan too! Now all I can hear is the rear hatch panels..... mad.gif
#9 Guest_Guest_MVFDV50_*_*
Posted 24 March 2006 - 03:33 PM
QUOTE(Guest @ Mar 24 2006, 03:31 PM) View Post
I don't have my passwork at work so I cannot logon as MVFDV50 here, i'll fix that tonight. blink.gif
#10 Drew
Drew
  • 191 posts
Posted 24 March 2006 - 07:28 PM
When my Volvo core leaked I caught it in time and there was no mess. However, on my old Saab when the heater control valve leaked and saturated the carpet I used a hose and shop vac. Pretty much flooded the carpet with the hose and shop vac'd it out. I repeated this several times until I had nothing but water, no green.
Then I proped up the carpet with whatever I could find and used a garage kerosene turbo heater for the day.
Looking back I'm suprised I didn't catch the car on fire.... ph34r.gif LOL biggrin.gif
A good wet vac and some heat will do wonders. It will dry.
I have also heard good things about the dehumidifier as well...
98' S70 GLT Auto with a little turbo.
#11 tendency
tendency
  • 380 posts
Posted 24 March 2006 - 09:13 PM
QUOTE(MVFDV50 @ Mar 19 2006, 07:38 PM) View Post
<SNIP..>
<..SNIP>
Watch out our you could end up with a wicked mold problem and *much* bigger problems.
It's not TOO bad of a job to tear out everything in the front down to bare metal and replace the sound deadining material that's under the carpet.
Upgrade your ride while you're at it with some premo deadening material such as can be found at:
Second Skin Audio
#12 98V70BASEBOY
98V70BASEBOY
  • 194 posts
Posted 25 March 2006 - 01:35 PM
I cut out the affected foam, soaked it in the tub (replaced water a number of times to get all the coolant out), put it out in sun to dry and then just put it back in. No problems, no smell, no nothing.
1998 V70 N/A
Stock except for custom treatment on center console.
151,658 miles as of 11/24/2008
