It starts out by buying the kit
a filter w/ instructions, the new black fitting
My instructions stunk out loud, yours prob will too
To start off for us early models, removing the temp sensor
HUGE PAIN
the torx screw is so very small you might get frustrated findding a tool thatll work...if your lucky youll get a perfect allen wrench..i wasnt.
after a pain to get the old useless black fitting out, and with the screw holes the old one had but new one didnt posed a problem
This becomes a game of drilling holes into the new piece of fitting so that itll fit in the hole...i changed to phillips screws, and cut the tips off. I screwed it neareer too the bottom towards the opening on the new fitting itself.
After this, took the extra step, and removed thhe cowl.(plastic covering youve been futsinng wiithh vents on itz) and removed the old trim which is now poking intoo the nice new filter...quite a pain
after removing that and sanding all the trim in that corner down, i fitted it all and it works great
In short: hopefully later models really do take like 25 miins
This topic is locked
