Blinking Arrow On Dash Of 94 850 Turbo
Posted 23 March 2006 - 12:15 AM
on my way back from work today, I noticed that my first gear was taking longer to shift into 2nd than usual...
I also noticed the blinking arrow sign on my dash board. I read in the owner's manual that it is a problem with tranny but not much more info...
When I got the chance to stop, I put the car in park, then back into drive and the first gear was shifting properly again. The damm arrow is still blinking though...
Is my tranny dying? Can it be that there isnt enough tranny oil?
HELP!!!
Thank you in advance!!
1994 850 Turbo Sedan
Eibach springs
#2 Guest_AlvinL_*
Posted 23 March 2006 - 12:24 AM
Posted 23 March 2006 - 01:18 AM
So basically that light will keep on blinking until I check the codes an reset it?
Also Bay13 says to check all codes before being able to reset... Does that mean I must read all codes for A1 or do I have to read all codes for all categories?
Sorry for the newbiness...
Edited by pimped_out_850t, 23 March 2006 - 01:45 AM.
Eibach springs
#4 Guest_AlvinL_*
Posted 23 March 2006 - 03:21 AM
Posted 23 March 2006 - 05:16 AM
#6 Guest_Guest_*
Posted 23 March 2006 - 01:26 PM
This morning I started the car... no more blinking arrow... everything seems fine... for now...
Posted 23 March 2006 - 02:40 PM
Pretty simple procedure, turn ignition on but dont start the car, foot on the brake, and ratchet the shifter from P to 1-2 back and forth about 20 times.
Good luck
1998 Jetta TDI
www.savetheinternet.com
Posted 23 March 2006 - 03:21 PM
Good luck
Exactly, it is an intermittent problem. I'm 100% sure that the arrow will return for you. It's best that you replace the PNP, or you'll be putting alot of stress on the tranny, and you're just asking for it. What happens is that there is a grease inside the switch, and when it gets old or hardened, it locks the PNP up and doesn't allow your tranny to shift properly. You can pull the PNP and open and try to clean it, but it's better just to buy a new one and throw it in. You can get one for about $100 from FCP or Ebay. If you remove the entire airbox assembly, you'll be looking right at it. Very easy job to do yourself. Just do some searching on here, we've all replaced em!
Posted 23 March 2006 - 04:00 PM
Change the PNP switch.
Posted 23 March 2006 - 07:00 PM
before i rip it apart for the manual swap i'm going to try cleaning the PNP just for the hell of it.
Justin
1998 Jetta TDI
Posted 23 March 2006 - 08:58 PM
try to change the relay and if doesnt help then go for the switch
relay is only 10-20 bucks and easy to install
Posted 24 March 2006 - 04:12 AM
Justin
didn't know about the noises...clean the PNP then and see what happens. get back to us with the results.
#14 Guest_AlvinL_*
Posted 24 March 2006 - 04:16 AM
HELP!!!
This doesn't sound like a typical PNP problem and getting the transmission codes read will quickly clear this guessing game.
#15
Posted 24 March 2006 - 04:41 PM
#16
Posted 29 March 2006 - 02:37 AM
Thanks!
This topic is locked
