Another Non-starting Issue
14 replies to this topic
#1 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 23 March 2006 - 01:07 AM
So, now my car isnt' starting too...
When the key is in the ignition position, the starter just whines (constant tone - no variation like it normally has). The engine is turning, but nothing is happening (no start). Battery has 12V until trying to start, voltage across the batt drops to 8V at that point.
Any suggestions or thoughts?
#2 Guest_Guest_whilst_*_*
Posted 23 March 2006 - 01:31 AM
QUOTE(jross @ Mar 23 2006, 01:07 AM) View Post
If you say engine is turning and starter has constant whine,I'd be looking at my compression.
Just a thought. Hope not.
Cheers.
#3 Guest_Guest_*
Guest_Guest_*
Posted 23 March 2006 - 02:24 AM
Only 8 volts while cranking??? The battery shouldn't dip below 9.6v. Try charging the battery and have it tested. Other than that, there just isn't enough info in your post for other possibilities.
#4 starfish
starfish
  • 749 posts
Posted 23 March 2006 - 02:26 AM
QUOTE(Guest @ Mar 22 2006, 08:24 PM) View Post
+1 That guy seems to know what he's talking about!!! ohmy.gif)
<insert witty comment here>
#5 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 23 March 2006 - 03:17 AM
QUOTE(starfish @ Mar 22 2006, 06:26 PM) View Post
I'll check the battery, that was one thing that bothered me. This car has eaten 2 other batteries this month (blew up an Optima! and just sort of butchered a Diehard). I'm also going to check the compression if the battery doesn't appear to be a culprit.
I've got half a mind to get rid of the battery and just have a 'shore power' terminal for starting mad.gif
#6 connorb850
connorb850
  • 974 posts
Posted 23 March 2006 - 03:25 AM
I would also check to make sure the alternator is not overcharging if you went through 2 batteries in a month.
1996 850 Turbo - SOLD
1996 BMW 328i
#7 Patrick.
Patrick.
  • 5,707 posts
Posted 23 March 2006 - 03:44 AM
QUOTE(connorb850 @ Mar 22 2006, 10:25 PM) View Post
took the words right out of my mouth
#8 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 23 March 2006 - 04:18 AM
QUOTE(connorb850 @ Mar 22 2006, 07:25 PM) View Post
The alternator appears to be ok.. the problem seems to be more the .3A current drain when the car is turned off.
#9 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 23 March 2006 - 05:07 AM
QUOTE(jross @ Mar 22 2006, 08:18 PM) View Post
what? check the glove box light!
#10 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 23 March 2006 - 07:06 AM
QUOTE(prasamin @ Mar 22 2006, 09:07 PM) View Post
I think that one is supposed to be a slow drain wink.gif But yes, I will check that smile.gif Thanks Pras
#11 ziddey
ziddey
  • 1,005 posts
Posted 23 March 2006 - 05:15 PM
stuff 0.3A is a lot
94 855t
#12 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 24 March 2006 - 11:43 PM
Hooked the car up to another (running) car and bypassed the battery, tried starting, no success.
The problem isn't electrical.
Any other ideas? I'm about to compression test and look at the timing belt.
#13 James100
James100
  • 874 posts
Posted 25 March 2006 - 12:06 AM
QUOTE(ziddey @ Mar 23 2006, 09:15 AM) View Post
stuff 0.3A is a lot
Maybe you have the "lawn mower syndrome" like several others had recently...
Read this Lawn Mower Syndrome
Check Engine Codes OBDI
Stage 0
PCV Pics
#14 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 25 March 2006 - 12:19 AM
QUOTE(James100 @ Mar 24 2006, 04:06 PM) View Post
Interesting thought.. but is hasn't been below 50 degrees here recently. If that is the problem, I'll probably notice it in the compression check though. Thanks for the suggestion!
#15 connorb850
connorb850
  • 974 posts
Posted 25 March 2006 - 01:23 AM
QUOTE(James100 @ Mar 24 2006, 07:06 PM) View Post
Definately a good suggestion, that is a common problem on these cars.
1996 BMW 328i
