Hi folks, did anyone have serp-belt tensioner fail?
FCP sells two kinds of tensioners, are they interchangable? Do different year cars have different mounting brackets for tensioner, pulley, steering pump, etc.?
Thanks,
Alex
Serpentine Belt Tensioner
Started by shurgen, Mar 24 2006 12:29 AM
Posted 24 March 2006 - 12:29 AM
96 855R 158k miles
Posted 24 March 2006 - 03:07 AM
Yes and Yes. I haven't had to replace mine, but I've read other posts on this forum from people struggling with this compatability issue. i would call FCP and ask.
'98 S70 GLT
Posted 24 March 2006 - 03:02 PM
The interchange-ability question, I can't answer.
The question of, do they fail?
Answer is YES, they do fail. I've had the tension spring break, (not on a volvo) and on my volvo, the internals had too much wear, and the pulley didn't run straight. It caused some weird noises. The belt actually started to ride up on the grooves of the power steering pump, and when it dropped back into the slots, it made a noise that sounded bad - like the pump was about to come apart. As the engine run, it would do this each time a certain place in the belt came around. (the belt looked ok)
Also, the bearing in the wheel has failed.
Experience is a hard teacher, it tests first and teaches afterward.
- Unknown
video
1993 850, 5 speed, 274k, Vogtland springs, Bilstein struts and shocks. Custom endlinks. Airbox mod, 20% tint. Future fun in progress.
- Unknown
video
Posted 25 March 2006 - 03:38 AM
Thanks guys for replies. My tensioner is making noise and I figured it will break soon, maybe. The noise comes from the part where the spring is but the noise is not as noticable after I drive for awhile. I know both rolers are ok (at least not making noise) on the tensioner and idle roler/pulley as noise changes when I pry on the top of the tensioner while engine running.
Has anyone put any lubricant into the crack from top of the tensioner?
96 855R 158k miles
This topic is locked
