Transmission Help!
9 replies to this topic
#1 kansan_brick
kansan_brick
  • 126 posts
  • Interests:alot
Posted 24 March 2006 - 01:23 AM
i have a few questions
whats the differance between a m56h and m56l also if there are any other manual transmissions that would be fairly simple to put in
and if u no any places to buy m56's
thank you
#2 JHEIII874T5M
JHEIII874T5M
    Level 6 Senior Member
  • 14,845 posts
Posted 24 March 2006 - 01:56 AM
calls you the search obi wan.
Joseph H. Essaye III
#3 kansan_brick
kansan_brick
  • 126 posts
  • Interests:alot
Posted 24 March 2006 - 02:45 AM
yeah i have been
#4 yangotang
yangotang
    yangbang!
  • 6,634 posts
  • Location:San Mateo, Commiefornia, Land of the Smog Nazis, Obamaland.
Posted 25 March 2006 - 09:43 AM
your kung fu is not strong.
Alex
#5 Gioseppe
Gioseppe
    Norcal Ninja
  • 5,422 posts
Posted 25 March 2006 - 10:10 AM
QUOTE(yangotang @ Mar 25 2006, 01:43 AM) View Post
+1
m56l has different ratios, and is rumored to be weaker then the m56h.
5spd options:m56,m58,m59... good luck finding the last two.
there's the m66 option, but that's a problem inside of itself....
Joe - 95 854 turbo manual - Ask me.
#6 bloc
bloc
  • 261 posts
Posted 25 March 2006 - 02:30 PM
just to throw a wrench into things, i suspect the m56L and H are the same transmissions, with different first and second gears.
via volvo parts program, no matter what final drive the L had, it always had slightly lower first and second gears. it was available in 3.77, 4.0, and 4.45 final drive ratios, but not 4.45 in the states. we only got the 3.77 in 93, 4.0 in 94, and by 95 they all seem to have been M56H, which always had a 4.0 final drive.
the 4.0:1 configuration of the M56L actually had a lower first and second final ratio than the m56H, which is a little pointless since most of our cars will just bake the tires then anyway.
L being weaker is just speculation, possibly from the fact that if you got a turbo manual in 94, it had a H on it.
this is more likely because it didnt need as short of a first and second gear.
1995 855 T-5M
1998 Jetta TDI
www.savetheinternet.com
#7 kansan_brick
kansan_brick
  • 126 posts
  • Interests:alot
Posted 25 March 2006 - 09:19 PM
now comes the quest of finding all the parts i need
#8 bloc
bloc
  • 261 posts
Posted 26 March 2006 - 02:20 AM
search. all the info is on here, though not in one place.
couple notes, pre-98ish Turbo or turboR clutch will fit right onto a NA flywheel and mate up fine with the transmission.
automatic axles will work though they arent as strong as NA manual ones.
to do the swap right you will need a manual ecu (or yours reprogrammed to manual, couple people on here can do it)
the interior trim around the shifter is different as well, though not enough to be a hugeproblem
1995 855 T-5M
1998 Jetta TDI
#9 kansan_brick
kansan_brick
  • 126 posts
  • Interests:alot
Posted 27 March 2006 - 12:29 AM
hwo much would an ecu reprogram be
and also would my speedometer still work after
#10 JHEIII874T5M
JHEIII874T5M
  • 14,845 posts
Posted 27 March 2006 - 04:46 AM
QUOTE(kansan_brick @ Mar 26 2006, 07:29 PM) View Post
contact jross... sales@centralresearch.net he'll let you know about that.
