i installed rear pads today as told in my other topic
when i went for a test drive it was raining outside i pressed brake pedal as hard as i could and it kind of trembled a couple of times almost in end like 15 mph (not shaked but like it wanted to go back) is this normal
is ABS worked like that because i tried couple of times and wheel didnt lock up maybe brake pedal was a sign that ABS was working
Is This Normal
Started by Dmsee, Mar 24 2006 02:45 AM
4 replies to this topic
Posted 24 March 2006 - 03:04 AM
If you pressed the brake pedal hard enough to lock up the rear wheels then the ABS system would have kicked in and you would feel the feedback on the brake pedal.
'98 S70 GLT
Posted 24 March 2006 - 03:12 AM
but i dont think rear locked up :)
it shouldn't, that's why it's called anti-lock
I think you're just feeling the feedback from the ABS, try it when it is dry, then get back to us
98' S70 GLT
EST Intake, 16T @ 15psi, Forged Rods, Speedtuning ECU, iPD HD TCV, iPD Cat-Back, Strut Brace, Bilstein HDs, iPD Grille, Jewel Headlights, 17" Canistos, 215/45/17 Kumho ASX Tires
This topic is locked
