Suspension Woohs
11 replies to this topic
#1 Big Will
Big Will
  • 2,201 posts
Posted 24 March 2006 - 05:35 AM
I hate frost heaves! Since I teach skiing I often travel a road in Maine full of very deep frost heaves and each week they get worse. Last week I had my right outer tie rod replaced (genuine volvo) and an alignment done. Everything was terrific. Two trips on this road later and my suspension clunks which I'm assuming is my endlinks...I'm holding out for Slater's one way or another.
But, my less sure noise is now when I go slowly over a deep rut, my front suspension makes a drawn out squeel when being compressed. Any ideas for this? I appreciate the help as always.
--Will
Suspension itself is original but has been going strong aside from the usual mounts endlinks etc over the years.
Me: "Yea."
#2 TheMan5952
TheMan5952
  • 628 posts
Posted 24 March 2006 - 02:03 PM
spring seat maybe? I'm not sure, maybe some one else will have an idea.
-Joe- '02 S60 T5
Ron Paul in 2008
Need a New interior? Local NW shop Jack's Upholstery
#3 Schwein
Schwein
  • 466 posts
Posted 24 March 2006 - 04:08 PM
i grew up in maine so i know all about frost heaves. but if you want to talk about ruining a car. come down to boston and live here for a year. then you'll be begging to take your car back to the "glass smoothe" roads of maine! lol wink.gif
#4 Big Will
Big Will
  • 2,201 posts
Posted 25 March 2006 - 06:49 PM
Yea, you're right that Boston is awful for potholes...so is New York by the way.
I realized that there's a little more to my post than I mentioned although this could be totally unrelated:
At speeds of about 30-35 mph, when I'm not on the gas the car vibrates more than it does at other speeds. I feel it in the steering wheel, shift lever, and my seat. It's not horrendous and I do have snow tires on but I feel like it's only at that speed. Any ideas?
Thanks.
--Will
Me: "Yea."
#5 rp850
rp850
  • 1,401 posts
Posted 25 March 2006 - 09:35 PM
Maybe one of the engine mounts? The one on the top of the engine is known to fail...just a thought.
QUOTE(Big Will @ Mar 25 2006, 12:49 PM) View Post
Thanks.
--Will
1995 855T
172,000 miles
#6 Guest_Guest_ashman_*_*
Posted 26 March 2006 - 05:13 AM
Its pretty normal for the spring to make noises when re-adjusting, Id have to hear it, but if its not too bad, I wouldnt worry about it.
#7 Guest_Guest_ashman_*_*
Posted 26 March 2006 - 05:17 AM
The vibration sounds bad it could be a cv joint or engine mount , unless its the engine...
#8 Guest_Guest_ashman_*_*
Posted 26 March 2006 - 05:22 AM
You could put the car in park and rev the engine to about 2000 rpm, if it vibrates then its an engine problem (bleh), if it only happens when its moving its probably a cv joint or maybe a drive axle problem, good luck.
#9 Big Will
Big Will
  • 2,201 posts
Posted 26 March 2006 - 05:38 AM
Ok guys thanks for the input. I don't think it's the engine as it only vibrates when I'm not on the gas so low rpms only. I thought about engine mounts though I have the IPD poly mount for the top and just replaced the mount behind that one that attaches to the firewall. I'll check some of the lower mounts.
Thanks again.
Me: "Yea."
#10 rp850
rp850
  • 1,401 posts
Posted 26 March 2006 - 02:46 PM
When you hit the bumps, are you hitting them with one wheel or both wheels? If it's one wheel, maybe it could be the sway bar mounts? Also, I read in the IPD catalog that if you suspect end links you can disconnect them and try to reproduce the noise. If you can't, then you found the culprit.
QUOTE(Big Will @ Mar 25 2006, 11:38 PM) View Post
Thanks again.
1995 855T
172,000 miles
#11 98V70BASEBOY
98V70BASEBOY
  • 194 posts
Posted 26 March 2006 - 03:57 PM
Just out of curiosity, you're not, by chance, talking about the road that goes over Streaked Mountain from Buckfield toward Sunday River are you?
Just one of many, so probably not. I know Rt 4 and 27 up to either The 'Loaf or Saddleback gets pretty nasty too.
1998 V70 N/A
Stock except for custom treatment on center console.
151,658 miles as of 11/24/2008
#12 Big Will
Big Will
  • 2,201 posts
Posted 26 March 2006 - 07:46 PM
I'm talkin about the road that goes through Hebron past Lost Valley...Rt. 119
But yes, 4 and 27 are bad as well...but not this bad!
Me: "Yea."
