It's Friday morning here in sunny Jacksonville, FL and I'm spending the morning replacing the driver's side outer CV boot. The axle came out without any problem.....but I knew that wasn't going to last long for some reason. I can't seem to get the outer bearing section with the wheel bearing splines to come out so I can put the boot on. I can keep the retaining clip open to their widest poing with a pair of hemostats, but even carefully smacking the bearing section gently with a small ballpeen hammer won't release it. Any suggestions? I'm going to get something to eat and come back to this site after lunch hopefully with an answer.
Thanks everyone...........
'95 850 sedan 114,000 miles
Help. Driver's Side Axle Out
Started by xraybob, Mar 24 2006 03:44 PM
9 replies to this topic
Posted 24 March 2006 - 03:44 PM
2002 2.4T S60
Posted 24 March 2006 - 03:51 PM
Your best bet is to go rent a fwd hub bearing puller from Autozone while you're out to lunch
edit: Something like this ... http://www.ipdusa.com/ProductsCat.aspx?Cat...5163&RootID=629
Edited by beachnut, 24 March 2006 - 03:55 PM.
- Scott
'05 S60 T5
'04 S80 2.5T
'05 S60 T5
'04 S80 2.5T
Posted 24 March 2006 - 09:06 PM
You may have already done this; but the best way is to mount the axle upside down in a vise with the joint you want to remove hanging down. If you have someone to help; have them open the clip while you knock off the joint with a large hammer and punch.
'98 S70 GLT
Posted 24 March 2006 - 10:24 PM
I won!!!! The extra set of hands worked. I'll still be getting the grease out of my finger nails for a couple of days, but it's worth the labor savings $$$$ I would have had to pay.
Thanks everyone.
Thanks everyone.
2002 2.4T S60
Posted 25 March 2006 - 12:32 AM
Hey Bob, pm me if you need any help. Iive Intracoastal West, just west of Jax Beach
2000 Mercedes W210
1995 854 NA Auto
RIP - Dad - M.G.T 10/31/42 - 12/03/05 "Press On"
1995 854 NA Auto
Posted 25 March 2006 - 04:55 AM
Hardcore! I've sucked it up and simply replaced the axle in the past.
Granted, I waited until I heard the clunk of death = rebuild only!
Posted 25 March 2006 - 06:28 PM
new axle is $89 with AAA discount from NAPA. How much is just the CV joint? Is it even worth while?
96 Turbo
Posted 27 March 2006 - 12:05 PM
It was about $25 from FCP Groton (boot kit only). To me, it's worth the savings, plus now I know how to do it.
2002 2.4T S60
Posted 27 March 2006 - 03:33 PM
that, to me, is worth doing the work alone
1995 855 T-5M
1998 Jetta TDI
www.savetheinternet.com
1998 Jetta TDI
Posted 02 April 2006 - 01:17 AM
[attachment=655:attachment]
I just discovered that my driverside CVB is also leaking
when I changed the oil today.
Xraybob, how about a write up so I can follow your lead in changing this sucker. Thanks in advance!
This topic is locked
