Serpentine And Tensioner Replacement
#1 rp850
rp850
  • 1,401 posts
Posted 24 March 2006 - 08:12 PM
Hi everybody,
I'm about to replace my serp belt, serp tensioner and idler roller.
Anybody have any tips or tricks they can give me to make this go smoothly?
I was tempted to use the Vise-grip and quarter trick but I decided I'd pay the $30 and buy the IPD tool which I hope will make the job pretty easy.
Also, if you know the torque specs for the tensioner and idler bolts I'd sure appreciate it!
Thanks.
1995 855T
172,000 miles
#2 James100
James100
  • 874 posts
Posted 24 March 2006 - 10:00 PM
QUOTE(rp850 @ Mar 24 2006, 12:12 PM) View Post
Hi everybody,
Thanks.
I used a 12mm crows foot(Sears) on a 3/8 torque wrench to get off the idler bolt...There is not much room there...
Check Engine Codes OBDI
Stage 0
PCV Pics
#3 rp850
rp850
  • 1,401 posts
Posted 24 March 2006 - 10:08 PM
Thanks. I don't have crows foot wrenches. I was planning on using my sockets, would that work? Maybe a stubby open end wrench if I can get enough torque on it?
If it's worth picking up the crows foot wrenches I gues I can do that. Harbor freight is right up the road...
QUOTE(James100 @ Mar 24 2006, 04:00 PM) View Post
1995 855T
172,000 miles
