Brake Line Removal
#1 stu.f
stu.f
  • 186 posts
Posted 25 March 2006 - 05:44 PM
Im trying to remove the rear brake line out of my caliper so that I can replace the caliper but I can't get the nut that holds the line in off and I don't want to round it. I used break-away, I heated it up, and I am using a flare nut wrench. Any ideas?
IPB Image
It may be a N/A but the paint is shiny ain't it?
93 850glt 5spd
K&N filter
Bilsteins
#2 BeachRat
BeachRat
    Team GKT
  • 2,761 posts
Posted 25 March 2006 - 08:01 PM
Can you fit a little bit of a cheater pipe over it? Make sure it's still mounted to the car before you try torquing it.
#3 pfeener
pfeener
  • 950 posts
Posted 25 March 2006 - 08:04 PM
Your doing all the right stuff, although I'd be real careful with the heat...not a great idea with brake fluid in a sealed space. I lot of us have had very good results with PB Blaster as a rust penetrator. (available at Auto Zone) I would soak it and let it sit overnight. Beyond that about all you can do is replace the line along with the caliper.
'98 S70 GLT
