Wheel Bolts For Aftermarket Wheels
5 replies to this topic
#1 SH8KDWN
SH8KDWN
  • 1,244 posts
Posted 27 March 2006 - 02:28 AM
I just bought a set of ICW wheels that came off an S80 and the wheel post adapters don't fit. I'd rather not use a post adapter if I didn't have to. I would prefer a wheel bolt with a head that is a little smaller and will fit into the recess in the rim.
(1) What is the bolt thickness and coursness of the thread?
(2) What is the measurement of a smaller diameter head?
Volvownage!
#2 turbowagon
turbowagon
  • 103 posts
Posted 27 March 2006 - 03:19 PM
I have the specs at home. I'll log in later. I think they are 1.75 x 12
CSF
FOR SALE: 1998 Volvo V70 AWD R Saffron 130K $4000
Speedtuning ECU, Boost Controller, EST intake, 2.5 inch downpipe to dual exhaust, and Enkei 18's
FOR SALE: 1996 Volvo 854 Turbo Platinum 160K $3000
Speedtuning ECU, V70R injectors, EST intake, 16T, 3 inch downpipe to 3 inch Catback, IPD/OMP/Koni Suspension, and Volan 17's
#3 James A Sousa
James A Sousa
  • 307 posts
Posted 28 March 2006 - 02:30 AM
Volvos use "hub-centric" wheels. If the hub does not fit properly, you will never get a satisfactory fit.
Lug nuts will not solve the problem if the hub is not tight.
#4 Drew
Drew
  • 191 posts
Posted 28 March 2006 - 04:26 AM
I'll look tomorrow for the bolt size if noone posts it as well. I do know it's a STRANGE size and not very common.
98' S70 GLT Auto with a little turbo.
#5 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 March 2006 - 05:36 AM
bolts are 12x1.75 with a 19mm conical head.
you need hubcentric rings to fit the wheels, unless the center is smaller that the hub, in which case you'll need to bore them out to match.
Edited by prasamin, 28 March 2006 - 05:36 AM.
#6 SH8KDWN
SH8KDWN
  • 1,244 posts
Posted 28 March 2006 - 04:20 PM
I have hub rings that fit and I bought wheel bolts that "should fit". The thread pitch looks too tight (not course enough). We will see.
Volvownage!
