Hi,
I have a 96 850 with the 5 spoke wheels. I keep getting a flat on one tire. I had the tire checked. I had the valve replaced. I had the bead sealant pu on. The tire still leaks. has anyone had a problem with leaking rims? can the rim itself leak? Any othe r ideas. It is a slow leak that wont flatten the tire completely. What else can i look for.
Flat Tire
Started by M850GLT, Mar 27 2006 04:08 PM
5 replies to this topic
Posted 27 March 2006 - 04:08 PM
96 850 GLT
Posted 27 March 2006 - 04:43 PM
More than likely if you have already replaced the tire there is a hairline fracture in the rim, they sometimes can be microscopic and hard to see with the naked eye, usually occuring somewhere near the spokes and rim. Just buy a new rim for ~$100 and be done with it.
1997 854 T5 :: TME ECU :: TME Cat-back Exhaust :: 17x7.5 Canistos :: Maxxis MA-Z1 215/45ZR17 :: 850R Front Spoiler :: Samco Hoses :: K&N ::
2004.5 S40 2.4i :: Completely Stock ::
2008 Porsche Boxster
Posted 27 March 2006 - 05:24 PM
Who has good replacement parts for volvos?
96 850 GLT
Posted 27 March 2006 - 06:12 PM
you have the glt? you might be able to look in the fs section or post in the wtb section and get some responses. the rim is probably not bent right? since i'd imagine the mechanic would have told you. so probably hairline indeed. You can always try the soapy water method and see if you see any bubbles anywhere
94 855t
Posted 28 March 2006 - 02:27 AM
Tons of rims on ebay.
Have you soaped the whole thing up, rim and all? If there is a leak, you should be able to find it.
This topic is locked
