During the process of changing out my oil cooler lines, I decided I needed a little extra room. So I put a jack and block of wood under the oil pan and raised the engine about an inch. I had this clip shoot out from under the engine. Picture attached. Can anyone identify? It looks like the expanding ring from the half shaft. If it is, how did it get out? Did I damage anything?
Oil Cooler Repair Done
Started by salesdeity, Mar 27 2006 11:52 PM
4 replies to this topic
Posted 27 March 2006 - 11:52 PM
1996 Volvo 850 T5
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
1/4 14.10 @ 105.90 mph
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
Posted 27 March 2006 - 11:54 PM
it's definitely a snap ring...
put the jack under the crossmember.. not the oil pan!
Posted 27 March 2006 - 11:57 PM
The car was on jackstands already. I just needed a little extra space to work. I don't lift the whole car via the oil pan.
So where does this ring belong?
1996 Volvo 850 T5
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
Posted 28 March 2006 - 12:00 AM
WHEW!
not sure on the clip..
Posted 28 March 2006 - 12:08 AM
I think the half-shaft has a different shape ring w/out holes on the tips. And I'd say it's ipmossible for it to come out. I'll keep thinking about it and maybe I will remember where it belonges. I will let you know if someone doesn't do it before me.
96 855R 158k miles
This topic is locked
