Please look at the pics. I have lots of oil that appears to be coming from just under the exhaust manifold on the driver's side of the block. I have changed the o-ring and gasket on the turbo return line.
I have always had a little oil around the turbo. But most of this oil seems to be coming from just under the exhaust manifold. Any ideas?
Oil Leak
Started by salesdeity, Mar 28 2006 12:00 AM
Posted 28 March 2006 - 12:00 AM
1996 Volvo 850 T5
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
1/4 14.10 @ 105.90 mph
IPD ECU and Exhaust
100K miles
Best G-Tech Times
0-60 5.79
Posted 28 March 2006 - 12:15 AM
Might be the RMS
1996 turbo 850 with 210K miles (3000+ miles per month) with IPD ECU w/MBC, yapping at you from Austin, TX
1998 V70 with 75K miles
Posted 28 March 2006 - 12:33 AM
Looks too high to have anything to do with the RMS. I would clean it up real good and keep an eye on it to see where it's coming from. If you look from the top of the engine, can you see any oil running down the back of the engine from the top?
'98 S70 GLT
This topic is locked
