Starting, 850 T5-r 1995
6 replies to this topic
#1 DigitalFusion
DigitalFusion
  • 5 posts
Posted 28 March 2006 - 09:24 PM
Hi everyone,
i keep having this problem with my car. normally it starts up fine and runs, however every once and a while i get this problem where the car will not start.
after putting the key into the ign. and turning it to start you here a click, but the engine does not turn over (the starter doesn't run) the car also locks itself automactically. the ABS, fog lights, traction, and radiator lights turn on. if the key is removed and you step on the brakes, all the previous mentioned lights glow back up slowly. the car cannot be taken out of park when the key is in and pressing on the brake. when the key is turned to ACC, the radio does not power on, the sun roof does not work, but the windows work, barely, they go extremely slow and sometimes do not function at all. the battery is charged so that is not the problem.
any ideas?
-Andrew
i forgot to mention, last time this happend i had it towed to a shop, however when it got to the shop it started fine.
850 T5R
#2 TG850T5R
TG850T5R
  • 610 posts
Posted 28 March 2006 - 10:41 PM
QUOTE(DigitalFusion @ Mar 28 2006, 01:24 PM) View Post
Hi everyone,
any ideas?
-Andrew
850's have a common ignition problem..... I am not quite sure what all the symptoms are but it sure sounds like it all has to do with your ignition? Did anyone take a look at it?
Volvoless in Seattle......
#3 shurgen
shurgen
  • 1,136 posts
Posted 28 March 2006 - 10:51 PM
The battery maybe properly charged but battery terminal connections may not be clean or tight. See if you can freely turn wire connectors on battery terminals.
96 855R 158k miles
#4 DigitalFusion
DigitalFusion
  • 5 posts
Posted 28 March 2006 - 10:53 PM
battery terminal is fine, i actually removed the battery for a while to see if tha twould fix the problem, which it didnt.
850 T5R
#5 shurgen
shurgen
  • 1,136 posts
Posted 28 March 2006 - 10:58 PM
QUOTE(DigitalFusion @ Mar 28 2006, 10:53 PM) View Post
Hm...Ignition switch maybe on its way out. How often do you have non-start problem? Has it been happening more often since the first non start?
96 855R 158k miles
#6 Plan_B
Plan_B
    Off-Topic Slut
  • 22,635 posts
Posted 28 March 2006 - 11:00 PM
My car did the same thing, it was the connections of the ignition, cost $75.00 to fix biggrin.gif
GAYTARD
#7 Swede Racer
Swede Racer
  • 14 posts
Posted 29 March 2006 - 06:52 AM
My 740 actually had that problem too. The dealer fixed it for $90.
IPB Image
1991 744 Stock
208k
Wanted: 850 Turbo
