What Is Needed To Pull An Engine?
Posted 29 March 2006 - 12:38 AM
thanks
98 C70 HPT M
Posted 29 March 2006 - 12:40 AM
huh?
oh- drop the subframe
cornellfsae.com
borgwarnerboosted.com
Posted 29 March 2006 - 12:44 AM
You *can* separate the trans from the engine but its generally easier to pull both out together. No problem at all with pulling it from the top, still connected. You don't have to remove the subframe. But you will need something to hoist it up with however.
Posted 29 March 2006 - 12:57 AM
huh?
yep, registered and then kinda forgot about it i guess. then someone suggested this was the best board for 850's so decided to start posting here. WAY faster then vp and swedespeed, likin it here
98 C70 HPT M
Posted 29 March 2006 - 01:25 AM
You can separate the tranny from the engine in the engine bay, but it's tricky. We ended up just pulling both out of frustration after wasting most of an afternoon attempting to separate them.
Plan to spend at least 2-3 days on your first time pulling the motor, and be aware there are ALOT of electrical connections that need to be unhooked (on the order of 30+). You'll need alot of PB'laster or WD40 for some of the bolts too. An extra set of hands when actually lifting the motor out is especially helpful as the engine bay is rather tight.
Posted 29 March 2006 - 02:36 AM
Posted 29 March 2006 - 02:40 AM
Posted 29 March 2006 - 02:51 AM
First time out? I can see it taking 2-3 days, yeah. I know most pro shops say it's a day in and a day out, I'm assuming a shade-tree mechanic here. It took me and a buddy (both of whom are 'resonably' mechanically inclined') 2 days to get my motor out. There's alot of little things - pulling the strut brace, the axles, the heater core hoses, the rad hoses, the oil hoses, all 20 million electrical connectors, and then when you actually are lifting the engine/tranny out you need to adjust it to get it past the ABS stuff, not to mention the A/C compressor and PS pump which you need to pull off with the engine partway out (well, in my case I had to. Stupid bolt on the A/C froze in place and I had to cut it out with a dremel and hacksaw). Oh yeah, and there's the fuel rail, and all the crap over by the battery that comes out, plus the tranny cables.. the list goes on and on.
Posted 29 March 2006 - 06:30 AM
It's About What's Under The Hood
Silicone Hose, Turbo Hose, Silicone Hose Kits
Posted 29 March 2006 - 06:41 AM
good luck!!!
Posted 29 March 2006 - 06:53 AM
by the way, i found it a LOT easier to pull the engine harness out of the ecu box than to disconnect every injector and sensor wire from the engine itself.
remove the ecu and tcu, take the toppart of the box off, depress all of the little retaining clips that hold the aluminum tray down, and it folds in half allowing the connectors to slide out.
1998 Jetta TDI
www.savetheinternet.com
#14
Posted 29 March 2006 - 08:02 AM
For the 850 maybe yes but with my '00 S70 I needed to take the passenger side headlamp out to remove a screw from the plastic cable cover coming from the ECU box. The screw was placed underneath the plastic inner front frame..
#16
Posted 29 March 2006 - 09:35 AM
#17
Posted 29 March 2006 - 10:02 AM
That is a VERY handy trick right there.. I wish I'd known that.
#18
Posted 29 March 2006 - 02:48 PM
and johann, is it a screw that you could leave out once it's removed to make future R&Rs easier, or is it too important?
1998 Jetta TDI
#19
Posted 29 March 2006 - 05:38 PM
Freezer bags with the white area for you to write on helps for bolts.
#20
Posted 29 March 2006 - 11:26 PM
This might sound like something you MIGHT want to do...but it is something you should DEFINITELY do.Everything you take apart(alternator,starter,water pump,etc)put the bolts in a ziploc bag and write what they are on the bag.The same with pictures.Take close ups and complete engine bay pics,especially of anything that looks confusing coming apart.
You will thank yourself ten fold on the reinstall.
Edited by Volvo Virgin, 29 March 2006 - 11:27 PM.
99 S70
This topic is locked
