Misfire Codes?
4 replies to this topic
#1 mike850r
mike850r
  • 311 posts
Posted 29 March 2006 - 03:50 AM
i appoligize, i forget the numbers, but im throwing misfire codes, misfire cylinder 2 twc damage(cat is shot anyways), and misfire at least one cylinder. it only does it under a load. ie. lots of boost/WOT. i did just wash up my engine bay friday...possably a little water in the cap?...and i suppose its gettin around that time for a tune up...any other ideas though?
'96 850R(sold i miss her)
240 5spd
#2 Volvoson
Volvoson
    Baby On Board Racing
  • 17,264 posts
  • Interests:Drinking, taking pictures, cars, and usually drinking.
Posted 29 March 2006 - 03:55 AM
I would guess that at least one of your plugs got wet when you washed the engine bay. I was throwing misfire codes a month ago, but it turned out to be injectors. Check your plugs first, they are cheap and pretty easy to get out smile.gif
View Postgdizzle, on 21 May 2012 - 03:52 AM, said:
All the clean cars are in the PNW.
#3 mike850r
mike850r
  • 311 posts
Posted 29 March 2006 - 04:05 AM
yea...injectors...lol....that sucks...i have a bad feeling thats what it is. unsure.gif
240 5spd
#4 Volvoson
Volvoson
  • 17,264 posts
Posted 29 March 2006 - 04:07 AM
QUOTE(mike850r @ Mar 28 2006, 08:05 PM) View Post
Well, it could just be a connector on one of the injectors that got wet, clean all of the connections on the plugs, distributer, coil, injectors, and if that doesn't fix the problem, post up your exact fault codes so we can help you out a bit more.
I personally doubt that the injectors got messed up out of all of the things that could go wrong with spraying your engine with water, my money is on plugs.
#5 mike850r
mike850r
  • 311 posts
Posted 29 March 2006 - 04:10 AM
lol...hopefully. but with 220k on her it wouldnt suprise me. o and while im at it...boost pressure regulation no status. i changed the hose and everything but it keeps comming back...wtf?
240 5spd
