Check Engine Light: Code Po108
1 reply to this topic
#1 alexanj2b
alexanj2b
  • 25 posts
Posted 30 March 2006 - 01:34 AM
I have a 98 s70 t5 with 173,000 miles. the engine light came on while on the drive way shortly after i started it. the code is PO108=manifold absolute pressure/BARO sensore High input. Can any one please tell me what it means and how i can fix? thanks in advance for your information. i really appreciate it.
#2 ms007
ms007
  • 396 posts
  • Interests:boating
Posted 30 March 2006 - 01:47 AM
Baro sensor is located on the rt side of the eng compartment behind the headlight in front of the module box has a pink connector going to it... see if it's pluged in..
96' 850R - Duelstage MBC - 18T - White Injectors - 17psi RICA flash - Phantom II gauges - 3" J downpipe -3" mandrel bent cat back - dynomax- O2 wideband-
16T straight flange for sale 275.00 SOLD
