Strange Fastener On Panel
6 replies to this topic
#1 pawn256
pawn256
  • 33 posts
Posted 30 March 2006 - 02:30 AM
I need to take off the front side panel of my car. I took off all the bolts I could find (most at difficult spots to get to), but...
There are fasteners of some kind connecting the panel to the wheel well. They aren't screws... They are little metal things with a rubber piece on the outside. How do I get them off?
Thanks!
Looking at 3 from the "backside" of the wheel well.
Looking at a different 3 of them from the outside.
PS: If a larger (closer up) picture would help please let me know and I can take more.
Edited by pawn256, 30 March 2006 - 02:32 AM.
'99 S70 GLT AUTO
K&N Panel Filter
IPB Image
#2 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 30 March 2006 - 02:32 AM
They are pop-rivets. Drill them out or use nippers to cut the back ends of them off.
#3 pawn256
pawn256
  • 33 posts
Posted 30 March 2006 - 02:36 AM
Thanks for the response. (sorry about the wrong forum... my final goal has to do with rerouting an air intake, but yeah, this post shoulda been here).
How do I replace these? (assuming i need too.)
'99 S70 GLT AUTO
K&N Panel Filter
IPB Image
#4 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 30 March 2006 - 02:42 AM
QUOTE(pawn256 @ Mar 29 2006, 08:36 PM) View Post
You need to buy a pop-riveter and some rivets. You can do that pretty cheap though. Under 20 dollars on ebay or if you shop around for a hand one. Very easy tool to use and loads of uses.
Did a quick search for you:
http://cgi.ebay.com/ebaymotors/POP-RIVET-G...625253599QQrdZ1
And NP about the wrong forum. I do it all the time. I just move my own posts though wink.gif
#5 MadeInJapan
MadeInJapan
  • 1,629 posts
Posted 30 March 2006 - 04:55 AM
I've seen the pop-revit gun and revits sold as a kit at BigLots....of all places! Cheap too. If you have these stores where you live, might be worth a little trip to their automotive section. ohmy.gif
'91 240 Sedan- Sold 4/21/09
#6 DVolvoguy850T5
DVolvoguy850T5
  • 340 posts
Posted 30 March 2006 - 04:28 PM
QUOTE(MadeInJapan @ Mar 29 2006, 10:55 PM) View Post
True that MIJ, $7.99 and comes with the rivets.
That being said, easy way to remove those rivets is to take a chisle wedge it under the head of the rivet and knock it off with a hammer. How ever those rivets are designed to just take a punch and push the centre of the rivet shaft upward and pull the rivet out with a pair of pliers or wire cutters.
You can use aluminium rivets but you will be takeing them out with a drill motor for sure.
I have a 97 855T5 now, have had 6 other Volvos in the past. Sux I aint got um any more!
#7 mbsl98
mbsl98
  • 697 posts
  • Interests:cars, boats, skiing, family, travel
Posted 30 March 2006 - 05:15 PM
best cheap answer for the replacement rivets is actually the dealer. They have the correct black ones with a wide lip(like a washer) that helps keep head from pulling through the plastic. I bought eight of them for around $2. total from the local dealer last year. A cheap hand gun is fine for installing them. Be sure you pick the right size compression fitting - most guns come with two separate fittings that look like hex nuts with a small hole in center. One of those is screwed onto the body of the gun as a storage spot, while the other is installed in the spot where you insert the rivet stem into the compression arm of the gun. If the hole there is not large enough for your new rivets, you just need to swap to the other size. Mostly, two sizes take care of most rivets in the size ranges we use.
Mike Sullivan
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
