Abs Sensors
Started by G_Money, Mar 30 2006 02:55 AM
12 replies to this topic
Posted 30 March 2006 - 02:55 AM
ABS/TRACS censor going crazy.....the code from the on-board computer of my 855 t5r says that all four ABS censors are going off at the same time and it was confirmed by the mechanic who just did some work on my car. the probabbility of all four censors going off that way is almost impossible per my conversation with him
do you guys have any idea of what could cause that?
95 855 T5-R
Monster S2R
Posted 30 March 2006 - 04:53 AM
Sounds like the ABS module to me. When it goes, all kinds of crazy things happen.
'91 240 Sedan- Sold 4/21/09
Posted 30 March 2006 - 05:23 AM
When all 4 ABS sensors are "gone" at the same time, it usually means the ABS module itself is gone. When I had my ABS repaired, the diagnostic report showed 13 ABS codes were set including all 4 sensors.
Send it to Victor. http://home.earthlink.net/~vicrocha/
Posted 30 March 2006 - 06:18 AM
Can it be fixed in other ways?
95 855 T5-R
Monster S2R
Posted 30 March 2006 - 06:21 AM
Sensors
s-e-n-s-o-r-s
Sensors
s-e-n-s-o-r-s
Sensors
Posted 30 March 2006 - 06:24 AM
I don't this is a DIY repair thing, or something a VSer was able to fix at home. A special press is needed to open up the plastic ABS housing as it is glued or sealed. Then you need to know which chips on the circuit board need to be replaced. It's worth the money to have it repaired if you plan on keeping your car for some time.
#7 Guest_AlvinL_*
Posted 30 March 2006 - 08:25 PM
What is the code(s)?
Posted 30 March 2006 - 09:56 PM
Check voltage to the abs unit if ok replace the module. There is reman units out there..
96' 850R - Duelstage MBC - 18T - White Injectors - 17psi RICA flash - Phantom II gauges - 3" J downpipe -3" mandrel bent cat back - dynomax- O2 wideband-
16T straight flange for sale 275.00 SOLD
Posted 31 March 2006 - 06:23 PM
Sensors
s-e-n-s-o-r-s
Sensors
s-e-n-s-o-r-s
Sensors
Pras,
Do you mean that all 4 sensors went at the same time?
Geoffrey's car is a 95! I was under the impression that 95's did not have this common module problem? In addition, previous owner did replace the module as far as I know and the problem did not go away?
Volvoless in Seattle......
Pras,
no, he's poking fun at Geoff who spelled Sensors with a "C"ensors, I have sinced fixed the spelling error in the title.
Posted 31 March 2006 - 06:24 PM
Roger that! Geoffrey is still learning and has waaaays to go :-)
Edited by TG850T5R, 31 March 2006 - 06:51 PM.
This topic is locked
