Hid Problem
9 replies to this topic
#1 Sinbad
Sinbad
  • 845 posts
Posted 10 July 2006 - 05:46 AM
So when I power up one of the HIDs, it flashes brightly about 5 times in a second, and then turns off... Is it dead? sad.gif
2006 SEAT Ibiza Cupra TDI
#2 tomtbone
tomtbone
  • 1,100 posts
Posted 10 July 2006 - 08:54 PM
hmmm I'm not sure, but go to HID planet and they can tell you over there.
97 855R - too many mods to mention ;)
#3 volvos60t5x
volvos60t5x
  • 321 posts
Posted 10 July 2006 - 11:50 PM
QUOTE(Sinbad @ Jul 10 2006, 12:46 AM) View Post
it can be the bulbs or the ballast, the best way to do is change the ballast each side and see what happen, and then do the same with the bulbs. Is hid kit? or oem?
Volvo S60 T5 5 speed --- BSR Intake, BSR Stage III, 278 whp, 328 lb-ft tq(Ecu upgrade, 3" down pipe, 3" Catback), SPEC Stage III+ Clutch, 4 Pistons Brembo calipers(front and rear), 18" pegasus, OEM body kit, 6000K Bixenon headlights, 6000K HID on the fogs, Bilstein HD, Evolve cooling Hoses
IPB Image
#4 volvo4lif3
volvo4lif3
  • 1,323 posts
Posted 11 July 2006 - 01:47 PM
Same thing happened to me, and it happened to be the bulb. What you can do is switch bulbs (put one side to the other) and see if the problem follows. More than likely, its the bulb....Same exact problem I had.
05 s60 2.5T
#5 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 11 July 2006 - 02:57 PM
Thats the ECUs self test to check the system. Is the other bulb burt out or something?
#6 Sinbad
Sinbad
  • 845 posts
Posted 11 July 2006 - 03:02 PM
QUOTE(Che @ Jul 11 2006, 04:57 PM) View Post
Other side is working fine. Haven't had a chance to swap the bulbs around yet. This is a Jamaica2G HID kit, so I doubt it's the ECU wink.gif
#7 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 11 July 2006 - 03:15 PM
QUOTE(Sinbad @ Jul 11 2006, 10:02 AM) View Post
Then why is this in Maintenance if your talking after market parts? Unless its a 55watt kit your going to have to rig it. The other option is to get your dealership to flash your cars ECU for HIDs.
#8 Sinbad
Sinbad
  • 845 posts
Posted 11 July 2006 - 03:22 PM
Cos I didn't know where else to put it? Please feel free to move it to a more appropriate place - thanks smile.gif
The kit has been working fine in the past. I had the same symptoms with this ballast and buld in 2 separate cars.
#9 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 11 July 2006 - 03:45 PM
QUOTE(Sinbad @ Jul 11 2006, 10:22 AM) View Post
Both 2001+?
You need to try them in an older car or just use the kits harness and wire direct to the battery. That will rule out a bad part.
#10 Sinbad
Sinbad
  • 845 posts
Posted 13 July 2006 - 08:54 AM
Fixed. It turns out one of the clips on the HT wires to the capsule had broken and there was a gap in the contact - it obviously arced across for the starter voltage but the run voltage was not enough to bridge... smile.gif
