TEKVOLVO
The Pookepipe!
Since Torquesteer's motor didnt blow up with the 100 shot of N20. I think 19-20psi will be fine.
19-20 psi without a built bottom end????
Either you're going to bend a rod here in the next few seconds or that's a tad exaggerated....
I run 18psi all day long on my car with stock tune and 12:1 afrs.. ;)
volvo for life oh yeah!*s... volvo for life.
I run 23lbs all day with 10:1 AFRs (above 4K), stock tune.
and also a turbo that isn't efficient past 18 :P
dam i thought i couldnt run more than 12 psi without messin stuff up but i guess i could go to 16 or so.
don't do it if you don't have a WB.
You have GOT TO be on crack my friend.
I'm running 18psi almost all day, and I have been up to 21psi without issue....just have to watch AFR's that's all.
Wow, you are right how does the Underlord, Javodoc, '95R and Torquesteer to name a few, seem to run @ 19psi w/o bending rods for all this time, maybe they should play the lottery :rolleyes:
Kev(underlord) runs 21 PSI all day long if I am not mistaken...
what the hell is a WB and can i just re-adjust my wastegate for higher pressure around 12 psi total boost with stock turbo? i can go for less presure im just wonderin.
Ah so if i get a $400 o2 thing i can do it then, id like to get a bigger turbo in the future but for now its stayin stock
IPD has a AF guage for like $60 plus S+H ;) although not available until August
