wlfbronco
Manual B Oost Controller,, Only 10# Of Boost
After installing tthe simplistic Hallman MBC,,, Ist run I could only get about 5# out of it,, the guy I bought it from told me he had it set at 13#,, so I figure, well maybe it somehow got turned down a bit when I was admiring it for 2 months before installing.... sooo I do a couple turns on it,,, maybe 6/7 lbs.... well this evening ,, its much cooler,, I cranked it up a bit on long stretch of rd. here in no. va... well after cranking it till it wont turn any more,,, 10#, with a spike to maybe 12,,,,
Car has a S/T 17# chip, full down pipe and exhaust ,, before I installed the mbc,,,, 17lbs easy,,,, I caped the vacum, nipple on the inlet tube and from the directions I've read here on line,,wasnt really necessary to cap the 3 ports on the Electronic boost controller, fairly new vacum lines,,,,
Am I missing something ???? Any ideas ????
Did you install the vacuum lines correctly on the MBC? Inlet is the line from the turbo, outlet goes to the wastegate.
If all lines are correct check for a boost leak, check the hose under your throttle cover, squeeze it to make sure it's not cracked. Also make sure your wastgate is working properly as well as your cbv, you could be losing boost in any of these places. How much boost were you holding prior to the mbc install?
flip the mbc around, see what happens.
btw... are you doing it inlet compressor line -> MBC -> wastegate? or wastegate off turbo -> mbc -> wastegate port on bcs? I'm expecting you to say the 1st one.
yup,, outlet to the wastegate inlet from the turbo
Try flipping it around, sometimes different MBCs act differently. I'm pretty sure you have it setup right though.
yup , the first one
Before I installed the mbc,, could run on up to 15/17lbs no prb.,,, may switch it back this week to see if there is an issue with stock ....
Did you try all the gears? I can only get 11 psi in 1st, but I boost 14 psi nicely in the others. I don't really see why you have a MBC if you're chipped and boosting fine with the chip.
The Hallman, does it look like this one?
IPB Image
If so, usuallly the top of that picture leads to the vacuum port on the turbo and the side of it leads to the vacuum port on the wastegate.
Looks exactly like that one,, and thats how its hooked up,, side port to the wastegate,, top port to the turbo,,,,
maybe the spring isnt strong enough for wahtever reason although if the PO of it was able to do 13psi, something seems astray
Try this... put all the vacuum lines back to stock. Then, put it inline with the wastegate. In other words, the wastegate line will go wastegate nipple on turbo -> MBC -> BCS.
Just went back and read the threads from the guy I bought it from,, said he had it set around 13#,, but was pushing it,, said if i wanted to run 17# then I'd have to go to the heavier spring,,, hmmmmmmm
Hey, am I the only one who boosts 17-18 PSI in every single gear??? I have a dawes that is set up about 4 inches from the turbo and waste gate. Maybe it is the boost controller design itself.
