Diy Immobilizer Antenna Ring Replacement
#1 3p141592654
3p141592654
  • 25 posts
Posted 11 August 2006 - 08:33 PM
I have a very intermittent start then immediate stall problem with my 2000 V70, and the problem is slowly becoming more prevalent. Its now about once a month. Can I replace the immobillizer antenna ring myself, or does it require software download after install?
2000 V70 SE
#2 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,926 posts
Posted 12 August 2006 - 08:04 AM
QUOTE(3p141592654 @ Aug 11 2006, 01:33 PM) View Post
It is a pretty easy install if I remember correctly. I dont think there is a software upgrade either.
Sonic Shenanigans
#3 3p141592654
3p141592654
  • 25 posts
Posted 12 August 2006 - 06:41 PM
Did a little more poking around. You're right, it does look straightforward.
2000 V70 SE
#4 cstem
cstem
  • 8 posts
Posted 13 August 2006 - 06:58 PM
Just did mine two weeks ago. No software update needed. You will need a phillips screw driver and a standard too. You take off the trim panels from around the column first. Then remove the two small screws (V40) for the wiper stalk and carefully slide it our of the way. Remove the one screw holding the immobiliser and unplug it. Install is the reverse. The antenna is only like $20.
