60ft? Mods?14.8 at 96 mph, kind of disappointing
I only got 3 runs in and it was my first time at the track (Lebanon Valley)
I'll +1 anyone who posts timeslips, decent videos of their runs, etc. I love a quality post
Posted 21 August 2011 - 01:53 PM
Posted 21 August 2011 - 02:10 PM
Wow Jake, an actual 1/4 time for a stock S60R that's close to the claimed stock time of 14.0.
Most S60R's that I've seen run 14.5+, nice job! The trap speed is way above the claimed stock track speed, as well.
long live vanessa 2.0!
Posted 21 August 2011 - 04:28 PM
Posted 21 August 2011 - 10:40 PM
60 foot was around a 2.2-2.3. I feel like I should be able to get a consistent 2.2 or even 2.1 with this car.60ft? Mods?
brake boosting at all? What tires are you running and how was traction? I know you can get a lot better then that
Posted 22 August 2011 - 12:11 AM
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
Posted 22 August 2011 - 02:09 AM
00 Olive V70R -- 89 244 DL
Posted 22 August 2011 - 04:28 AM
Posted 22 August 2011 - 04:44 AM
time for something with more punch then a 16t
no time to go on a cooler night when u can get like 10 runs in and actually get an accurate time, i know your car and that just doesnt seem right to me
Posted 22 August 2011 - 01:24 PM
Is that what you normally keep your tires at? Any chance you checked them when they were warmed up? Seems fairly high. I used to run 40psi on Falken Fk452 205/55/16 and it was harsh as fuck. Did you make any change to tire pressure for the track night? If you were having traction problems, I'd try lowering them a bit. But it sounds like you were suffering more from bogging than anything else.Running Hankook Ventus V12 Evo K110 at 44 psi on all four corners.
Posted 22 August 2011 - 03:00 PM
Yep, I know people always say that's a high pressure to run at. However I like the firm ride and added steering response with the higher pressure. I had a feeling I should have dropped the pressure down to the high 30's before hitting the track, but I wanted to see how they did at this pressure. My guess is they only went up another 1-2 psi from driving.Is that what you normally keep your tires at? Any chance you checked them when they were warmed up? Seems fairly high. I used to run 40psi on Falken Fk452 205/55/16 and it was harsh as monkey. Did you make any change to tire pressure for the track night? If you were having traction problems, I'd try lowering them a bit. But it sounds like you were suffering more from bogging than anything else.
Posted 09 September 2011 - 02:40 AM
And like you said, I truly feel that it was more of a launching/bogging issue resulting in my times.
Posted 17 September 2011 - 04:43 AM
2004 Volvo S60R - 3" Catless downpipe, 3" catback, ARD Carbon Tune, 4C Delete
Posted 20 September 2011 - 09:23 AM
14.33@99.62
Mods in sig.
Posted 20 September 2011 - 02:38 PM
nice stuff man.. ill be getting an exhaust soon.. happy to see somone else is in the low 14's wtih me
you 6speed?
Posted 21 September 2011 - 01:25 AM
Yes, 6 speed. A little over 120K miles also
you 6speed?
Yep it's a purdy R
Also complete with saffron winglets
Posted 31 May 2012 - 02:25 AM
Posted 14 July 2012 - 03:57 AM
Posted 15 July 2012 - 01:24 AM
40 is quite high, i work in a tire shop and have done lotsa stuff with different stuff haha. 35-37 is tops i would run around every day. at 40 you will be wearing your centers of your tires out. i am currently running my Cooper Zeon RS3-A's at 30 because the normal 35 was too high. We will see i guess prolly end up around 32. Track you could easy run 30ish at the highest... Just my imput
Posted 16 July 2012 - 05:57 PM
What size are you running curious? I am pretty much kicked on mine and I did enjoy them but now that they are on coming right up to the wear bars... they feel very on edge to say the least. I assumed that as tread wore down you would SLOWLY lower the pressure (1-2 psi) as well but I am still on edge but if I go much lower the tire looks flat (although its not) and sorta holds the road like a floppy cock
Biggest little 16T in the world upgrade?
Posted 17 July 2012 - 03:08 AM
