Still Have Excessive Boost Problem
34 replies to this topic
#1 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 01:31 AM
Ok so I have changed the CBV and associated vacuum lines. I am still getting excessive boost (upwards of 20 psi this time) and the boost is still fluttery when in the high psi (15+). The car feels very sluggish now when pulling away and but it boosts to higher psi (15+) extremely quickly and gets to almost 20psi with no problems. I am living at around 5000-6000 feet and at idle in drive I get just over 20 inHg. The vacuum stays constant so I am guess no leaks. Anyone got any ideas??? I would like some feedback.
Golden Gate VCOA Club Secretary
www.SharpHID.com - plug & play HID conversion kits - PRICES LOWER THAN EVER!!
'00 V70R - totaled :(
2002 Audi Allroad 2.7T (daily driver) - 1986 BMW 325es (daily driver)
#2 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 31 August 2006 - 01:52 AM
when did you start noticing this?
1989 BMW 325i - 1992 Volvo 240 - 1992 Vespa PX200E
1993 Bridgestone RB2 'porteur-plaisir' conversion - 1995 MASI Gran Corsa - 1996 Gunnar Roadie
#3 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 01:57 AM
QUOTE(rodrigo @ Aug 30 2006, 09:52 PM) View Post
When driving into the mountains of Colorado using boost the whole way up.
#4 RAzOR
RAzOR
  • 2,198 posts
  • Crew:SCC
Posted 31 August 2006 - 01:58 AM
John,
You might have a broken BCS or a bad wastegate actuator. Take the hose from the CBV and hook it right to the wastegate. You should have no boost ever. If you do, the wastegate controller is bad.
Make sure your BCS is connected right. I THINK: CBV to bottom, intake hose return middle, wastegate actuator top.
#5 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 01:59 AM
QUOTE(RAzOR @ Aug 30 2006, 09:58 PM) View Post
John,
Explain those BCS connections again? How do I hook the cbv hose to the wastegate, is there a nipple on the wastegate?
#6 Mesoam
  • 18,673 posts
Posted 31 August 2006 - 02:03 AM
take your foot out of the pedal
96 854 R, CLICK ME
The Jeep
#7 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 02:05 AM
QUOTE(Mesoam @ Aug 30 2006, 10:03 PM) View Post
It is hard when I have to put it down to hold speed going up the hills into the mountains. I can be boosting 15-20psi just holding speed, it's rediculous. The car is very sluggish unless I am in the right gear. Didn't use to be like that.
#8 96PlatinumEdition850
  • 789 posts
  • Interests:My
Posted 31 August 2006 - 02:28 AM
Sluggish part sounds like a misfire at higher boost.
96' 850 Platinum
#9 FluidGroove
FluidGroove
  • 36 posts
Posted 31 August 2006 - 04:14 AM
if the vacuum line is disconected from wastegate your car will boost whatever it wants too, mine poped off and was boosting upwards of 22 psi. luckily i found the cause. re attached and back to 15. dunno if its the same as yours but mine was the dotted red line
2001 Volvo S40 Midnight Metallic
TD04-14T, 3in downpipe, Magnaflow, K&N filter, turbo XS MBC, intercooler hardpipe, silicon lines, Autometer gauges
KW's Variant 1, H brace, TME strut brace, VMS droplinks, VMS rear strut brace, 5000K HID, Twin piston dump valve
Zimmerman rotors, EBC green stuff, 17x7 5zigen, 215/45/17 nitto neogen
#10 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 04:49 AM
QUOTE(FluidGroove @ Aug 31 2006, 12:14 AM) View Post
I am pretty sure I replaced that one but I'll double check.
I don't think I am getting misfires. Engine is purring like a kitten even at 20psi.
Any other thoughts?
#11 MadeInJapan
MadeInJapan
  • 1,629 posts
Posted 31 August 2006 - 06:07 AM
You didn't mention any codes...hard to believe you're not getting any with the issues you're having...such as for the altitude sensor.
'91 240 Sedan- Sold 4/21/09
#12 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 06:09 AM
Well I have had a check engine light on for some time due to the bad Cat. I guess that is a good point. I will go get the codes checked.
#13 FluidGroove
FluidGroove
  • 36 posts
Posted 31 August 2006 - 06:11 AM
QUOTE(leurven @ Aug 31 2006, 04:49 AM) View Post
actually im sorry, not the line to the wastegate but the one on the lower right. not cbv. its the last one
#14 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 06:12 AM
Hmm.... think I changed that too. There were three down there I did. I'll look at them all again.
#15 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 05:36 PM
Still looking for more thoughts on this topic?? Anyone? Is it worth me replacing the wastegate?
#16 leurven
leurven
  • 2,911 posts
Posted 31 August 2006 - 08:36 PM
Seamus? Any ideas?
#17 leurven
leurven
  • 2,911 posts
Posted 03 September 2006 - 12:45 AM
Nobody knows of anything else? I find this hard to believe. Turbos are turbos and I know people here know more about it than I do. At sea level i was getting upwards of 30inHg doing 75mph on the highway. At 6000 feet I am getting 20-22 or so at that speed. Boost doesn't go past 17 at sea level but is still fluttery. At 6000 feet I can get over 20psi and fluttery boost and even less power than down at sea level in hotter weather. Any ideas guys? Does it sound like a wastegate problem or a new turbo solution?
#18 leurven
leurven
  • 2,911 posts
Posted 04 September 2006 - 10:13 PM
Turns out it is the BCS. Time to buy one to confirm this.
#19 leurven
leurven
  • 2,911 posts
Posted 06 September 2006 - 01:47 AM
BCS replacement has not fixed the problem? Any other ideas guys?
#20 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 06 September 2006 - 03:01 AM
QUOTE(leurven @ Sep 5 2006, 09:47 PM) View Post
13g.
