Ac Blowing Hot Air For A Few Minutes At Normal Temp
14 replies to this topic
#1 nervegrind3r
nervegrind3r
  • 70 posts
Posted 11 September 2006 - 06:56 PM
This just starting occuring last week. In the morning on my drive to work, I put the AC on after the car has reached normal operating temperature. The AC is on low (2 or 3 bars) at 72 degress, and it blows hot air for several minutes. If I crank the AC to full blast, hot air is still blowing out. After 4 or 5 minutes, the its starts blowing out cold air.
Is it time to replace some parts, any thoughts? Thanks in advance
'02 S60 NA
#2 DouginDenver
DouginDenver
  • 454 posts
Posted 11 September 2006 - 10:50 PM
QUOTE(nervegrind3r @ Sep 11 2006, 12:56 PM) View Post
I take it that once it blows cold, it's as cold as it should be? Idf so, I assume your major mechanical components (compressor/evaporator, etc) are fine, but something is not telling it to turn on - the thermosat in your car or something.
'99 C70 LPT convertible - nautic blue/tan - all stock - 42,000 miles.
'00 S40 1.8t - summer green/gray leather - 97,000 miles.
#3 nervegrind3r
nervegrind3r
  • 70 posts
Posted 12 September 2006 - 03:39 AM
QUOTE(DouginDenver @ Sep 11 2006, 06:50 PM) View Post
Thanks for the feedback.
very true, once it gets going, its fine. The hot summer is gone, why is why this is strange because its cold/warm outside in the morning. I never had a prob before just kicking the AC on before last week.
How do I know if I need to replace the thermostat and where is it located? thanks
'02 S60 NA
#4 bmcintyre
bmcintyre
  • 200 posts
  • Interests:Prosecuting DUI's ... and now Volvos
Posted 12 September 2006 - 03:52 AM
Maybe it just needs a recharge?? my wife's car (a very soon to be replaced Kia) was doing the same early in the summer and a recharge solved the problem.
B
NA's = Slow down and watch the sunset.........
#5 BtownVolvo
BtownVolvo
    Level 69 Member
  • 8,326 posts
Posted 12 September 2006 - 03:58 AM
Next time you start your car, look at your ac switches and see if they flash.
I don't think that it's a recharge problem.
Reid | 1998 V70 T5
Posted ImageT5power, on , said:
loggygagging
#6 96PlatinumEdition850
  • 789 posts
  • Interests:My
Posted 12 September 2006 - 04:05 AM
My car did that. It blew hot for a little bit and then cold. A few weeks later it blew warm randomly and then would go back to cold. Now it blows nothing but warm. Good thing it's nice outside. Now that it only blows warm if I have the AC turned to AUT and have the temp kicked down to 60 and the fan going you can here a click and you see the vacuum go up like it's turning on but then it kicks off and the vacuum goes down.
96' 850 Platinum
#7 Guest_Guest_*
Guest_Guest_*
Posted 14 September 2006 - 09:51 PM
QUOTE(96PlatinumEdition850 @ Sep 12 2006, 04:05 AM) View Post
the AC switches do not flash, everything seems to be working properly on the panel. I rarely use the AC since I like to drive with the windows down, but I started using it because I smelled a foul stench the one time I did use it over the summer. Even when it wasn't on, I noticed the stench since it seemed there is air always coming out even when its turned off. The more often I used the AC, the less the foul stench appeared. Now the stench is gone, but it blows hot when I turn it on.
#8 nervegrind3r
nervegrind3r
  • 70 posts
Posted 14 September 2006 - 09:52 PM
'02 S60 NA
#9 GavinV70
GavinV70
  • 16 posts
Posted 14 September 2006 - 10:53 PM
The stench could possibly be coming from a badly fouled or mouldy HEPA cabin air filter. Probably worth while checking it out smile.gif
#10 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
  • Interests:Stuff and beer.
Posted 15 September 2006 - 02:17 AM
The stench is proabably mold on your evap core, I recommend spraying lysol down the cowl and changing the pollen filter. The other problem could be something wrong with your damper motors. You can take it to the dealership and they can read the codes in your CCM.
Sonic Shenanigans
#11 nervegrind3r
nervegrind3r
  • 70 posts
Posted 15 September 2006 - 02:46 AM
QUOTE(GavinV70 @ Sep 14 2006, 06:53 PM) View Post
checked the cabin filter 2 weeks ago, and its fine. I replaced it like 2 months ago.
QUOTE
Im not very fond of my local volvo dealership. I'd like to try your suggestion if I knew where the cowl is located. Can you point me in the right direction?
thanks for the feedback, its truly appreciated
'02 S60 NA
#12 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 15 September 2006 - 02:50 AM
QUOTE(nervegrind3r @ Sep 14 2006, 07:46 PM) View Post
Right were your windshield wipers are that is the vent right there, make sure you turn recirc off.
Sonic Shenanigans
#13 bmcintyre
bmcintyre
  • 200 posts
Posted 15 September 2006 - 03:15 AM
[/quote]
[/quote]
a recharge mean it needs R134 or whatever the new name for environmentally freindly Freon that makes the AC system all chilly and stuff.
#14 howardc64
howardc64
  • 171 posts
Posted 21 September 2006 - 03:24 PM
My had a none working temperature sensor in the ECC which gave a different symptom (no heat until MAX temp setting). There is a heated wire temperature sensor inside that 3 opening slit on the ECC. There is a fan that sucks air flow thru that wire to sense the cabin temp. My fan was jammed with threads.
See "Jammed ECC Temperature Fan spindle" in my website below for full info
http://howards01v70t5.blogspot.com/
Don't know if yours is the same/similar problem. Listening for the fan noise after shut off is a quick diagnostic.
I also hear there is another temperature sensor behind the rear view mirror. Haven't looked at that.
01 V70XC 117k mi (5/12) 11 Prius II 48mpg! 01 V70 T5 ASR sold 4/12
Maintenance History
#15 BMonk
BMonk
  • 34 posts
Posted 22 September 2006 - 05:43 PM
I had a problem on my old 94 where it would only blow cold air for a couple minutes and blow hot.
That turned out to be a bad compressor.
I don't think that the original posters problem though as his trouble is it not cooling fast enough.
I do have a suggestion on the stink though. I have used a product called Evaporator Odor
Control. Comes in a spray can made by FJC airconditioning products. Kills the mold and other
smells. Leaves a nice mild lemon scent. Works real well. I dont know what the price per can
is but if you can't find it local let me know and I'll mail you a can at cost. I have one left. You
spray in into the return air intake. I have one can left I don't mind parting with. I bring all
my paints and stuff in the basement for the winter and the less is better...
Bill
Mystic,CT
Here is a link to the product (I get mine from local autosupply)
http://store.lenzdist.com/product.php?xProd=675
Edited by BMonk, 22 September 2006 - 05:45 PM.
99 XC
