Bad Day With My S80
12 replies to this topic
#1 dishwatcher2
dishwatcher2
  • 59 posts
Posted 12 September 2006 - 12:52 AM
Ok over the past few weeks my 01 S80 with 80K miles has been running very rough. I replaced the plugs with liitle effect. Had no ODBII codes, but felt 80 would be cood to change.
Today on my way to the office the car stalled out at a light. I ad trouble restarting it and keeping it running. Tac drops to 5K and dies.
Same problem tonight on my return trip home.
ODBII is reading out
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem
P1608 PCM Malfunction
P0172 System too Rich - Bank 1
Yes it makes sense that the engine was running very rich and starving for air.Not sure what cylinders make up Bank 1 or what is the PCM.
Do I just need to swap the MAF?
Air Mass Meter Bosch (OEM) $191.11
Any help or way of diagnosing the MAF?
#2 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 12 September 2006 - 12:53 AM
Wheeee! ETM!
#3 garbergtsi
garbergtsi
  • 411 posts
Posted 12 September 2006 - 12:55 AM
that could defenitly be a MAF also....
you dont see rich codes associated with ETM's very often
#4 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 12 September 2006 - 12:56 AM
QUOTE(garbergtsi @ Sep 11 2006, 05:55 PM) View Post
don't ruin my fun.
it's the MAF.
#5 dishwatcher2
dishwatcher2
  • 59 posts
Posted 12 September 2006 - 12:59 AM
QUOTE(the underlørd @ Sep 12 2006, 12:53 AM) View Post
Wheeee! ETM!
Not sure what you mean by ETM Very Often. Please explain.
Your sure it's the MAF $190
#6 SkyWriter
SkyWriter
    I'm so back in the game!
  • 2,526 posts
Posted 12 September 2006 - 01:08 AM
he means to check out thethread below abou ETM problem.
http://volvospeed.com/vs_forum/ETM-Softwar...med-t45901.html
not other will a rich condition be reported. ETM problem usually result in stalls and poor idling and other throtle relared problem. it's probabley not the ETM. but theres no excuse for you own research. and if it's wrong then you don't have to worry about blaming someone else that know no nothning and S80s smile.gif
I'm sad and lonely. Someone please hug me
#7 ovlovtech
ovlovtech
  • 11 posts
Posted 12 September 2006 - 03:17 PM
You could try unplugging the MAF sensor. This will make the ecm default to pre set values. If it is the MAF sensor it will most likely run better with it unplugged.
#8 dishwatcher2
dishwatcher2
  • 59 posts
Posted 13 September 2006 - 11:20 PM
I did unplug the MAF, engine ran worse. RPM's went from near zero to a high of 500RPM. Never settled out at 1K. I would not run this engine long in this condition as it sounded terrible.
As soon as I replugged in the MAF the engine wanted to run better, but stll very rough idle.
#9 ovlovtech
ovlovtech
  • 11 posts
Posted 14 September 2006 - 12:00 AM
You could have a dirty throttle ( as I have seen you want to know how to clean it ). By the way is your car turbo?? If so maybe there is a leak in your intake system.
#10 dishwatcher2
dishwatcher2
  • 59 posts
Posted 16 September 2006 - 12:54 AM
QUOTE(ovlovtech @ Sep 14 2006, 12:00 AM) View Post
No no turbo. Yes I want to ensure its not just dirty. I have pulled the top half of teh intake manifold off. Exposed the air cambers to each cylinder, very dirty.
I'll cleanig them up later this week-end.
I am looking some direction on cleaning the TB. What is the BEST cleaner? Why not Carb Cleaner?
#11 SkyWriter
SkyWriter
  • 2,526 posts
Posted 16 September 2006 - 03:22 AM
read the many ETM sticky threads. should be enough info there. good luck. i'll be there soon myself.
#12 Guest_Guest_*
Guest_Guest_*
Posted 16 September 2006 - 11:39 PM
QUOTE(SkyWriter @ Sep 16 2006, 03:22 AM) View Post
Isn't the eTM all covered 100% by volvo now? I think so. At any rate, a bad O2 sensor would also screw up fuel mixture and give you a bad idle at times. Just a thought.
#13 Guest_Guest_*
Guest_Guest_*
Posted 16 September 2006 - 11:43 PM
QUOTE(Guest @ Sep 16 2006, 11:39 PM) View Post
could also be the infamous intake manifold gasket. Has anyone not had that problem?
by the way, I am registered, I'm just on someone else's pc. thanks
