105k Service On S60
13 replies to this topic
#1 Guest_JMH_*
Guest_JMH_*
Posted 12 September 2006 - 07:42 PM
I've got a 2001 S60 T5 which is almost up to 105k miles. I know I need a timing belt, but have gotten quotes all over the place. Everything from $360 - for just the belt and tensioners, to $725 for the same, up to $843 for the complete 105K service (including timing belt, etc).
Anyone have a clue what REALLY needs to be done at 105K?
#2 garbergtsi
garbergtsi
  • 411 posts
Posted 12 September 2006 - 09:13 PM
nothing really NEEDS to be done....let er go til she blows
#3 s60wot
s60wot
  • 173 posts
Posted 13 September 2006 - 03:26 AM
QUOTE(garbergtsi @ Sep 12 2006, 05:13 PM) View Post
that's a terrible idea. Preventive maintenance is your friend.
2001 S60 T5 - 18T - Vibrant FMIC - Full 3" straight no muffler dual Magnaflow resonators - BSR Stage III PPC - Green Injectors - K&N panel - Snabb intake - AEM Uego controller - silicone vac lines - QBM Mounts - 17" Falken RT-7M wheels - Elevate front sway w/ TKI HD endlinks - IPD rear sway w/ HD links - Blackout Eggcrate grill - painted eyebrow tails - M Rear Lip spoiler - Koni/Eibach FSD's - R Manifold - Sharp HIDs - 3M Di-Noc CF console[/center]
#4 leurven
leurven
  • 2,911 posts
Posted 13 September 2006 - 03:28 AM
I'd say just do T-belt and have them check the accessory belt and tensioners etc... There may be some work needed there too. Have a Volvo place do it.
Golden Gate VCOA Club Secretary
www.SharpHID.com - plug & play HID conversion kits - PRICES LOWER THAN EVER!!
'00 V70R - totaled :(
2002 Audi Allroad 2.7T (daily driver) - 1986 BMW 325es (daily driver)
#5 loseR99
loseR99
  • 644 posts
Posted 13 September 2006 - 03:33 AM
i recently bought all of the parts for my 105k service, t-belt - tensioner - idler - water pump - fuel filter, most everything else i've done. Will be doing the service about 10k early too. With something as critical as a timing belt job, i wouldn't wait until i rolled exactly 105k. I'd source some quality parts online and find an independent mechanic. On my s40, parts were $200 total, and i was recently quoted at $300 plus coolant for the labor. I'd also check serpentine belt system, fuel filter, pcv system, plugs, thermostat, etc. If the complete service you mentioned includes the majority of these parts as well as labor costs, i think that you've found the answer. Best of luck with the service.
1999 V70R AWD FWD - Laser Blue - IPD polys, SharpHIDs, Eggcrate, TKI Endlinks, Marshall Instruments LED boost gauge, SNABB Pipe, Stylin Intercooler Hoses
2001 Volvo S40 1.9T - heavily modded 250hp 300ftlb - SOLD and missed often.
#6 SkyWriter
SkyWriter
    I'm so back in the game!
  • 2,526 posts
Posted 13 September 2006 - 03:55 AM
do what the maintenance schedule calls for, when it fails down the road it probavly does more damage besides gets you stranded. it's cheap insurance, unless you're poor.
I'm sad and lonely. Someone please hug me
#7 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
  • Interests:Stuff and beer.
Posted 13 September 2006 - 04:40 AM
QUOTE(leurven @ Sep 12 2006, 08:28 PM) View Post
W3RD
Sonic Shenanigans
#8 dos_vovo
dos_vovo
  • 16 posts
Posted 13 September 2006 - 06:28 PM
If you can afford it - have it done for you.
If you can't and have: some grasp of engines in general - the tools - and the time - DIY
www.eeuroparts.com for the parts
volvospeed.com for the clues
dos_vovo
roho s70 '99 145k
blanco s60 '02 49k
#9 Guest_arob_*
Guest_arob_*
Posted 13 September 2006 - 11:23 PM
my dad's s60 has 121k on it and it runs fine and we didnt replace anything
#10 leurven
leurven
  • 2,911 posts
Posted 14 September 2006 - 04:36 AM
QUOTE(arob @ Sep 13 2006, 07:23 PM) View Post
When the timing belt snaps you won't be very happy. Maintenance is so you aren't left stranded on the side of the road. I would get the work done when Volvo recommends.
#11 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 14 September 2006 - 06:45 AM
QUOTE(leurven @ Sep 13 2006, 09:36 PM) View Post
When the timing belt snaps you will be
A.) Replacing the engine
or
B.) Junking the car
It's in the owners manual for a reason....
Sonic Shenanigans
#12 leurven
leurven
  • 2,911 posts
Posted 14 September 2006 - 07:07 AM
You didn't spend all that money on an XC90 just to let the maintenance slide. Sell the car and buy a honda if you don't want to work on it or do maintenance.
#13 oddferkout
oddferkout
  • 142 posts
Posted 14 September 2006 - 06:09 PM
So true. I have a good story about that with the Saab I had before I got my S40. Best change it when Volvo recommends it. The car will treat you much better in the long run.
'04 X3 2.5i | '03 S60 2.4T
#14 pfeener
pfeener
  • 950 posts
Posted 16 September 2006 - 02:18 PM
To JMH: Follow the owners manual for the common stuff. Flush the antifreeze and the brake fluid every 2-3 years. Flush the transmission fluid every 50K or so.
As you already know, you need to do the timing belt at 105K or when it breaks it will take out the top end of the engine to the tune of $3-4K. You also have to replace the tensioner. The mechanical tensioner is only good for one belt change. It will come apart before the next belt change is due. The water pump is a variable. So folks do replace it and some don't. More than likely it will go the 200K to the next belt change.
'98 S70 GLT
