Cleaning Pcv On '99 V70xc
14 replies to this topic
#1 Jackorain
Jackorain
  • 7 posts
Posted 18 September 2006 - 12:41 PM
My 127K V70XC intermittently turns into a smoke bomb. I understand this may be a clogged PCV system has documented how thi is done. If so can you link me to it. I did a search but is difficult because one can not search PCV (3 letters)
Also i understand that i can clean the TB/ETM to eliminate my lumpy idel, is this right?
Jack
99 V70 XC
#2 garbergtsi
garbergtsi
  • 411 posts
Posted 18 September 2006 - 10:43 PM
you have to pull the throttle body off, the p/s pump out then remove the banjo bolt and clean it. i would just take off the throttle and clean out the small vacuum hose and the banjo bolt with a pick myself...
but on the other hand your volvo dealer is obligated to do it for free if you are experiencing ETM problems
#3 MasterT
MasterT
  • 5 posts
Posted 20 September 2006 - 01:44 AM
Ake for recall 155 qnd never have to worry about cleaning the throttle again.
#4 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
  • Interests:Stuff and beer.
Posted 20 September 2006 - 02:48 AM
QUOTE(MasterT @ Sep 19 2006, 06:44 PM) View Post
Yeah but 155 doesn't cover the PCV cleaning.
Sonic Shenanigans
#5 rodrigo
rodrigo
    Chatroom Scare Crow
  • 7,417 posts
Posted 20 September 2006 - 11:39 AM
QUOTE(MasterT @ Sep 19 2006, 09:44 PM) View Post
...not a good thought i dont think...
1989 BMW 325i - 1992 Volvo 240 - 1992 Vespa PX200E
1993 Bridgestone RB2 'porteur-plaisir' conversion - 1995 MASI Gran Corsa - 1996 Gunnar Roadie
#6 dos_vovo
dos_vovo
  • 16 posts
Posted 20 September 2006 - 04:13 PM
QUOTE(rodrigo @ Sep 20 2006, 07:39 AM) View Post
indeed - there is plenty of info on what 155 does. I didn't gather that ceasation of PVC - vac line - ect. maint. was one of the benifits.
dos_volvo
roho s70 '99 147k
blanco s60 '02 48k
#7 garbergtsi
garbergtsi
  • 411 posts
Posted 20 September 2006 - 10:00 PM
yes, the extended warranty covers PCV cleaning, where do you guys get your info?!?
#8 dos_vovo
dos_vovo
  • 16 posts
Posted 21 September 2006 - 12:19 AM
QUOTE(garbergtsi @ Sep 20 2006, 06:00 PM) View Post
granted - While under the boundries of this extended warrenty cleaning is covered.
interprepted - once warrenty ends - you still gotta clean the affected parts - thus - ceasation of pvc cleaning is not a benifit - yes!? wink.gif
dos_vovo
roho s70 '99 147k
blanco s60 '02 48k
#9 garbergtsi
garbergtsi
  • 411 posts
Posted 21 September 2006 - 01:30 AM
200k/10 years is a long time...
#10 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 21 September 2006 - 01:37 AM
QUOTE(garbergtsi @ Sep 20 2006, 03:00 PM) View Post
I guess I never read te entire TNN, but my boss told me it was not covered. Oh well.
Sonic Shenanigans
#11 Pauloil
Pauloil
  • 506 posts
Posted 21 September 2006 - 01:44 AM
i took my V70xc in for the upgrade and wanted to pay to have the PCV cleaned after 30K.
AS part of the upgrade, they first checked my PCV for free, finding it OK. I think the PCV has to be ok for the upgrade.
first time at around 60K, the mechanic cleaned it using long hoses and pliers and some spray. $37.50.....
1995 850 glt rattling down the road at 157K
99 V70XC 120K
#12 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 21 September 2006 - 01:47 AM
QUOTE(Pauloil @ Sep 20 2006, 06:44 PM) View Post
I'd like to see that trick. I remove the intake manifold. I guess some guys remove the PS pump and now that I think about it, that makes a lot of sense.
Sonic Shenanigans
#13 dos_vovo
dos_vovo
  • 16 posts
Posted 21 September 2006 - 02:12 AM
QUOTE(garbergtsi @ Sep 20 2006, 09:30 PM) View Post
It's all relative.
At the time I bought roho - he had 63k - that was 3 years ago.
Today he is pushing 147k. In the last 18 months the usage frequency changed dramatically.
I drive 1200 to 1500 miles a week.
Averaged: 1350 miles a week x 52 weeks = 70200 miles
70200 + 147000 = 217200
I have experienced some of the issues asscociated with 155. But I have not had the upgrade applied as of yet.
[As a matter of fact, I just recently did belts, tensioners, plugs, flushes, and PVC cleaning- prior to this I had been geting ETS indicators and CEL with regularity - after the maintenace - I disconnected the battery for an hour. That was a week ago - and now 700 miles into the 1350 mile week - no CEL, no ETS.]
As I was saying, it's all relative - a long time? From my perspective it's another year. It I get it done at all.
dos_vovo
roho s70 '99 147k
blanco s60 '02 48k
#14 garbergtsi
garbergtsi
  • 411 posts
Posted 21 September 2006 - 03:42 AM
Dmelvi--
i just take off the ETM...dont remove the banjo bolt. just remove the little vacuum hose going to it. take a paperclip and clean out the nipple going to the vacuum hose(right by the banjo bolt) then take a straight pick and clean out the hose.
ive done this many times and has fixed every one, using a manometer to check crankcase pressure.
oh yeah, and PCV cleaning is part of the ETM warranty. they say before replacing the ETM you need to check crankcase pressure/vacuum. there should be a slight vacuum to the crankcase and if there is not you are supposed to clean it and they pay you (pretty good) under warranty
#15 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 21 September 2006 - 05:57 AM
QUOTE(garbergtsi @ Sep 20 2006, 08:42 PM) View Post
Dmelvi--
Yeah that is pretty much what I do. I don't actually take the manifold off I just get it loose so I have a little more room to work. I think you get 3.something to do one, I've always cashed on it.
Sonic Shenanigans
