Anyone know what range the coolant temp should be in the resevoir after normal driving on a 85 degree day?
My radiator fan comes on with the a/c but not when I turn off the car.
Seems like it should kick on since my coolant is reading about 200 degrees in the resevoir.
Coolant Temp
Started by s60wot, Sep 18 2006 08:28 PM
Posted 18 September 2006 - 08:28 PM
2001 S60 T5 - 18T - Vibrant FMIC - Full 3" straight no muffler dual Magnaflow resonators - BSR Stage III PPC - Green Injectors - K&N panel - Snabb intake - AEM Uego controller - silicone vac lines - QBM Mounts - 17" Falken RT-7M wheels - Elevate front sway w/ TKI HD endlinks - IPD rear sway w/ HD links - Blackout Eggcrate grill - painted eyebrow tails - M Rear Lip spoiler - Koni/Eibach FSD's - R Manifold - Sharp HIDs - 3M Di-Noc CF console[/center]
Posted 20 September 2006 - 03:50 PM
Problem solved!
Replaced ect and now everything is back to normal
$50 and about 20 minutes work
Posted 21 September 2006 - 05:03 AM
Glad we could help!!
Seamus (sh'ay_mes)
98 V70R AWD-6, 540 ci (8.8L) 345hp Christen Eagle biplane, Cessna 180, 93 Ducati 750ss (my little sweety!), 98 VFR 800, XR 600,
Posted 26 September 2006 - 03:37 AM
Well, I thought it was fixed.
The fan came on by itself and ran a few times but a couple of days later it isn't working again.
Could it be the fan module? I understand they go out pretty easy. Is there a way to test the module since the fan does come on when the a/c is running?
Or, do I just replace the auxillary fan and module unit?
This topic is locked
