CEL's, 2000 V70R
15 replies to this topic
#1 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 20 September 2006 - 09:25 PM
P0171 & P1238... leading me to think... fuel pump... anyone have any thoughts?
#2 garbergtsi
garbergtsi
  • 411 posts
Posted 20 September 2006 - 09:54 PM
doubt it
#3 POOKDIZZLE
POOKDIZZLE
  • 2,340 posts
  • Interests:Family, working out and dropping $ into the Volvo.
Posted 20 September 2006 - 10:02 PM
QUOTE(the underlørd @ Sep 20 2006, 05:25 PM) View Post
What do the error codes=? I'm not at work right now so I can't look it up, but let me know what they mean and I can give you an idea wink.gif
1996 850R MANUAL 4-SALE $6795
18t,m56h swap w/r clutch and lightened flywheel,20psi custom RICA tune,a-tech intercooler,white injectors,na cams,na tb and na intake mani,r exhaust mani,rip kit w/tial bov,ur pulley,3" dp to tme exhaust,K&N cone intake filter,hr lowering springs,18" anthracite pegs w/225/40/18 tires,nitrous express wet kit w/remote bottle opener,wire ground kit,mbc,samco hoses,mesh grill,innovate wideband and 25psi boost gauge,tme strut brace,4-10" JL Audio subs w/JL Audio 500/1 amp, dynamat trunk kit,aluminum dash kit, alpine deck and changer,phoenix gold and pioneer speakers,tinted windows,custom side markers,r emblem door locks.
#4 garbergtsi
garbergtsi
  • 411 posts
Posted 20 September 2006 - 10:05 PM
0171 = lean
1238 = boost control solenoid
#5 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 21 September 2006 - 01:29 AM
i got a lead onto the AMM, thinkin' MAF?
#6 garbergtsi
garbergtsi
  • 411 posts
Posted 21 September 2006 - 01:33 AM
vacuum leaks first, if none prolly maf....but with that boost code that throws it off a bit...how does it run?
#7 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
  • Interests:Stuff and beer.
Posted 21 September 2006 - 01:35 AM
Boost control valve? Vacuum Elbow?
Sonic Shenanigans
#8 garbergtsi
garbergtsi
  • 411 posts
Posted 21 September 2006 - 01:37 AM
99+ dont have the vacuum elbow...
#9 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 21 September 2006 - 01:40 AM
QUOTE(garbergtsi @ Sep 20 2006, 06:37 PM) View Post
mmmm good point
Kevin tell you boss to go buy the real Volvo scan tool. Generic codes mean nothing to me.
Sonic Shenanigans
#10 leurven
leurven
  • 2,911 posts
Posted 21 September 2006 - 03:36 AM
Can't be fuel pump as that doesn't throw codes. What are the symptons?
Golden Gate VCOA Club Secretary
www.SharpHID.com - plug & play HID conversion kits - PRICES LOWER THAN EVER!!
'00 V70R - totaled :(
2002 Audi Allroad 2.7T (daily driver) - 1986 BMW 325es (daily driver)
#11 garbergtsi
garbergtsi
  • 411 posts
Posted 21 September 2006 - 03:38 AM
it could be the fuel pump, and yes it can throw codes....but its not very common
#12 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 21 September 2006 - 05:32 PM
the cars got a bit of a funny idle (the ETB was already replaced) sometimes. Ordered a new MAF, let's hope that does the trick.
#13 Hott C70T5M
Hott C70T5M
  • 23 posts
Posted 21 September 2006 - 08:55 PM
I dont know guys, i have similar problem with my c70, first it was the Maf and then I replaced it, then the coolant temp. sensor set a code, after erasing this the coolant temp code the maf code was set again. So, I decide to take the car to the dealer. And it seems like their confused as I'am. What the car would do, is- when at full stop it will die on me, also put to much fuel into the engine so it makes it hard to start it, also it will cut the engine power while driving and pick up again.... So today I went back to the dealer to see if they have found anything and they said that is possible for my boost valve to be the reason. But again they are not sure. If I knew what it was I would of fixed it myself, but unfortunatly I dont.
Any ideas? It is not a tune up for sure..
Edited by Hott C70T5M, 21 September 2006 - 08:58 PM.
Current:BMW 540I 6-speed M-package and BMW 1991 M3
Past: '98 Volvo C70 T5M ; Suzuki GSX-1000R and the list goes on and on....
#14 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 21 September 2006 - 09:18 PM
QUOTE(Hott C70T5M @ Sep 21 2006, 01:55 PM) View Post
replace the BCS.
#15 Hott C70T5M
Hott C70T5M
  • 23 posts
Posted 21 September 2006 - 10:02 PM
Thanks Kevin! Hopefully this will solve my issues with the vehicle. The dealer is charging me $51 for the part and with the diagnostics everything will cost me around $240.
#16 leurven
leurven
  • 2,911 posts
Posted 22 September 2006 - 12:45 AM
QUOTE(garbergtsi @ Sep 20 2006, 11:38 PM) View Post
My Volvo mechanic specified the actual pump doesn't throw codes. Doesn't mean that things around it aren't failing due to lack of fuel or too much fuel.
