Help! Help Me Troubleshoot...
10 replies to this topic
#1 VolvoC70
VolvoC70
  • 15 posts
Posted 22 September 2006 - 04:11 PM
Hey guys,
I've had my 2001 C70 "44,000 miles" for a month or so and I have a brand new porblem. 5 or 6 days ago I turned the key and it wouldn't turn over. It's not the starter, that sounds good. I turn the key back for a minute i'll try again and it starts up fine. There is no consistency to whats going on. I turn my car on 5 or 6 times a day and 30% of the time it does this. It been doing this the last 5-6 days. The engine can be cold or hot, it doesn't matter. Its happened on flat surface and on hills. One or two time the car actually revved up like it was going to stay on and then it shut down.
I have a date with a Volvo specialist next tuesday but I dont want to get stranded in the mean time and i'd like to go in there with some input on the problem so I dont get hosed...
Ken
'01 C70 5 speed
#2 ViperVette
ViperVette
  • 4,381 posts
  • Interests:Anything fast enough to do something stupid in... Cars/Girls/Boats...
Posted 22 September 2006 - 04:13 PM
I have a 2001 and I JUST had to get my battery replaced like a month ago. Not saying its your problem, but you might need one in the near future. I also had a wierd problem with dead starts, where it would start then stall. That seems to have corrected itself somehow. Wierd.
Tom
01' 72T5M
Oooo, thats nice.
HRE 19's Sonic Blue
06' M3 Competition Pkg
#3 Lynn Brockman
Lynn Brockman
  • 42 posts
Posted 22 September 2006 - 05:35 PM
Hmmm. Ignition switch? It would be inconsistent and could produce these results, right?
- Lynn
#4 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 22 September 2006 - 05:44 PM
guessing its the ignition antenna.
#5 POOKDIZZLE
POOKDIZZLE
  • 2,340 posts
  • Interests:Family, working out and dropping $ into the Volvo.
Posted 22 September 2006 - 06:11 PM
Yeah, the antenna rings have been known to go bad and cause results like what you are describing wink.gif
Edited by POOKDOG, 22 September 2006 - 06:11 PM.
1996 850R MANUAL 4-SALE $6795
18t,m56h swap w/r clutch and lightened flywheel,20psi custom RICA tune,a-tech intercooler,white injectors,na cams,na tb and na intake mani,r exhaust mani,rip kit w/tial bov,ur pulley,3" dp to tme exhaust,K&N cone intake filter,hr lowering springs,18" anthracite pegs w/225/40/18 tires,nitrous express wet kit w/remote bottle opener,wire ground kit,mbc,samco hoses,mesh grill,innovate wideband and 25psi boost gauge,tme strut brace,4-10" JL Audio subs w/JL Audio 500/1 amp, dynamat trunk kit,aluminum dash kit, alpine deck and changer,phoenix gold and pioneer speakers,tinted windows,custom side markers,r emblem door locks.
#6 POOKDIZZLE
POOKDIZZLE
  • 2,340 posts
Posted 22 September 2006 - 06:15 PM
part # will be either 9447804 or 8650054 depending on vin, they go for @ $50 + software charge.
#7 VolvoC70
VolvoC70
  • 15 posts
Posted 22 September 2006 - 09:57 PM
If this is the problem, I feel a lot better. I know these cars are known for electrical issues so I started to worry right away... I'll tell you how it went after Tuesday. I need to get the regular service check done anyway so i'm going in regardless. Also, it sounds like people here are always looking for good places to to take their car. I'm going to Peters Auto Works in Tigard, OR and they are Volvo specialists and they have all the Volvo tools and a DYNO. I'll tell you what I think about them after my first visit. I hear they like to mod there.
'01 C70 5 speed
#8 garbergtsi
garbergtsi
  • 411 posts
Posted 22 September 2006 - 10:44 PM
"it wouldn't turn over."
that is NOT an antenna ring, and again there is no software associated with replacing an antenna ring anyways!
on to the real problem, ive seen alot of times corrosion on the small wire going to the starter causing this, or possibly an ignition switch.
#9 VolvoC70
VolvoC70
  • 15 posts
Posted 23 September 2006 - 12:43 AM
maybe I used "not turning over" incorrectly. It tried to start, the battery is good and starter sounds fine. I could hold the key forward and it would try but it just wouldn't fire up. Like I said, it has also fired up 2 or 3 times but died right after too.
'01 C70 5 speed
#10 POOKDIZZLE
POOKDIZZLE
  • 2,340 posts
Posted 23 September 2006 - 12:49 AM
QUOTE(garbergtsi @ Sep 22 2006, 06:44 PM) View Post
I'll have to double check on the software but the new v50's and s40's get software with a new antenna ring and those symptoms are very similiar to the diagnosis of this.
#11 garbergtsi
garbergtsi
  • 411 posts
Posted 23 September 2006 - 01:00 AM
ok...if it didnt start, but turned over, im wrong. more than likely it is your antenna ring, although it could be other things also...
and yes, the 04.5+ S40/V50 need programming, but that is because its not just a transmitter, its a control module/ignition switch.
