Oil Leak By Filter
6 replies to this topic
#1 Pauloil
Pauloil
  • 506 posts
Posted 23 September 2006 - 03:10 AM
my 99 V70XC has a leak by the filter case: the oil drips on the bottom of the plastic filter cover and across the bottom of the motor not alot, but persistent.
I changed the oil and after seeing the leak did take the filter off to check everything and be sure the o-ring was there.
one little thing I did was drive 4 miles with the fill cap off, but not much oil came out and I was able to wipe it off and clean everything.
Any ideas about what is causing the leak? I did check to be sure the filter was tight.
1995 850 glt rattling down the road at 157K
99 V70XC 120K
#2 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 23 September 2006 - 03:20 AM
did you knick the gasket mating surface in the process maybe?
#3 leurven
leurven
  • 2,911 posts
Posted 23 September 2006 - 03:24 AM
Did you crack the oil filter canister? Could also be coming from above. Clean it and then trace it later.
Golden Gate VCOA Club Secretary
www.SharpHID.com - plug & play HID conversion kits - PRICES LOWER THAN EVER!!
'00 V70R - totaled :(
2002 Audi Allroad 2.7T (daily driver) - 1986 BMW 325es (daily driver)
#4 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
  • Interests:Stuff and beer.
Posted 23 September 2006 - 04:39 AM
Could it be residual left over from the oil? Or it could be your front seals leaking sad.gif
Sonic Shenanigans
#5 Pauloil
Pauloil
  • 506 posts
Posted 02 October 2006 - 02:18 AM
it was just from the change: i've just never seen so much! I had my wife drive the car so I wouldn't worry about it.
the bottom of the motor is still oily but no more drips and the level is fine after 400 miles.
99 V70XC 120K
#6 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,728 posts
Posted 02 October 2006 - 02:11 PM
QUOTE(Pauloil @ Oct 1 2006, 07:18 PM) View Post
Souns like residual, that is why I spray them down with brake clean after I get them all sealed up.
Sonic Shenanigans
#7 leurven
leurven
  • 2,911 posts
Posted 03 October 2006 - 04:47 AM
QUOTE(Pauloil @ Oct 1 2006, 10:18 PM) View Post
Make sure you don't have more than one seal on that canister for the filter. Also, make sure you oil the O-ring for the canister if you replace it just to give it a better seal.
