P1332
4 replies to this topic
#1 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 26 September 2006 - 12:08 AM
anyone had this issue, and how was it resolved?
#2 garbergtsi
garbergtsi
  • 411 posts
Posted 26 September 2006 - 05:55 AM
any oil problems? pressure/quailty, ect?
if no, replace the reset valve with the new gasket and hope it goes away.
has any recent enginework done? TB?
#3 Lynn Brockman
Lynn Brockman
  • 42 posts
Posted 26 September 2006 - 01:55 PM
If it is related to the VVT solenoid, or pre-ignition issues, the VVT solenoid/valve should be removed, disassembled, cleaned, lubed, and reinstalled with the new gasket. There have been issues with it sticking due to infrequent oil changes and sometimes due to metal shavings from the manufacturing process, and the new 'screened' gasket helps this, I hear.
- Lynn
#4 Seamus
Seamus
  • 347 posts
  • Interests:Airplains, Aerobatics, Motorbike racing, Volvo!!
Posted 26 September 2006 - 02:31 PM
Check your timing belt marks. If the cams are off a tooth this code will be set..
Edited by Seamus, 26 September 2006 - 07:09 PM.
Seamus (sh'ay_mes)
98 V70R AWD-6, 540 ci (8.8L) 345hp Christen Eagle biplane, Cessna 180, 93 Ducati 750ss (my little sweety!), 98 VFR 800, XR 600,
#5 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 26 September 2006 - 06:25 PM
