Plugs For S80?
#1 jl2
jl2
  • 232 posts
Posted 29 September 2006 - 07:58 PM
Any opinions re: choice of plugs for an 03 S80? The original Volvo plugs have 3 electrodes. Any problem using Bosch Supers? Any other suggestions? What are the gapping and torque specs?
2003 S80, Non Turbo
#2 BtownVolvo
BtownVolvo
    Level 69 Member
  • 8,326 posts
Posted 29 September 2006 - 09:03 PM
Stock plugs work just fine...anything platinum should work fine too.
This is for the 02's but it should be the same:
Torque to 30Nm (22 lb-ft)
Not sure on the gap...i couldn't find it
Reid | 1998 V70 T5
Posted ImageT5power, on , said:
loggygagging
#3 nervegrind3r
nervegrind3r
  • 70 posts
Posted 29 September 2006 - 09:27 PM
QUOTE(BtownVolvo @ Sep 29 2006, 05:03 PM) View Post
sorry if im jacking the thread a bit. What kind of torque wrench would you recommend for those small jobs like this? the ones I see in stores and at autozone don't go this low. What an accurate tool to put in spark plugs that don't need alot of torque? Last time I replaced mine, I just tightened them snug with a normal socket wrench.
'02 S60 NA
#4 jl2
jl2
  • 232 posts
Posted 30 September 2006 - 11:58 PM
QUOTE(BtownVolvo @ Sep 29 2006, 09:03 PM) View Post
Found the torque and gap info -
18.4 ft/lbs 25 nM
0.028-0.032 (.7-.8mm)
2003 S80, Non Turbo
