Oil Trap Replacement
9 replies to this topic
#1 Guest_timw_*
Guest_timw_*
Posted 03 October 2006 - 07:35 PM
any advice would be appreciated. Dealer wants 375.00 to do this says it takes 4 hrs labor. The part costs 45.00..just wonderin how hard it is to do this? thanks Tim
#2 Zappo
Zappo
    The One Upper
  • 15,531 posts
Posted 03 October 2006 - 08:32 PM
QUOTE(timw @ Oct 3 2006, 12:35 PM) View Post
I assume you asked if you have to remove the intake manifold. The answer is yes; the trap is located right below it. 4 hours sounds about right if you are changing the whole PCV system. If you are changing the trap, might as well do the whole thing to do it right.
#3 firepuma
firepuma
  • 1,047 posts
Posted 03 October 2006 - 09:52 PM
YEah, about 4ish hrs. don't forget to pick up a intake manifold gasket as well. You can forgo the intake tube (most $$ of pcv system) just give it a good cleaning. FCP groton www.fcpgroton.com has awesome deals, just make sure to call them with your specific make/model the trap system changes practically every year!
'00 V70R Olive. SOLD.
'99 v70 5-speed n/a nautic/tan leather. is wicked awesome. Blue/Tan Bilsteins/H+R/Borbet- sold!
'04 Acura MDX rollin' on 19's TRADED.
'05 subaru legacy 2.5gt manual - '11 sti block, vf52 yada yada losta powa 335whp/383wtq
'12 subaru outback 2.5i premium
#4 smokin' T5M
smokin' T5M
  • 936 posts
Posted 07 October 2006 - 03:02 AM
Manifold comes off. Is it an 80 or a 60? turbo or non turbo. all makes a difference
#5 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 13 October 2006 - 12:43 AM
Yep need to know the model?
"SMOKE TROUT NOT CRACK"
#6 MadeInJapan
MadeInJapan
  • 1,629 posts
Posted 13 October 2006 - 04:35 AM
QUOTE(MrWinkey @ Oct 12 2006, 08:43 PM) View Post
Yes, as the setup is different as well as the trap between models (even within the 850 range).
Also, someone suggested just changing the trap and cleaning the hoses (not buying the replacement hoses). My experience was that the so called hoses are no longer hoses...they are brittle, hard and plastic like after they are old.
You do have the option though of going silicone hoses instead of the factory hoses for the trap to the intake hose (from the air box), but the other very short connector hoses from trap directly to the block (1-2 inch pieces) and the one to the top of the engine really can't be anything but the Volvo kit. Therefore, as suggested by someone else,
Oh, and don't forget the intake manifold gasket.
'91 240 Sedan- Sold 4/21/09
#7 Seamus
Seamus
  • 347 posts
  • Interests:Airplains, Aerobatics, Motorbike racing, Volvo!!
Posted 13 October 2006 - 03:18 PM
I find it easier to remove the accessory bracket not the intake. You can just place the PS pump and the AC aside without disconnecting the hoses and remove the alternator all together, followed by the aluminum bracket. After that you have a great shot to the PCV canister. On the S80 you will have a hard time doing it without removing the bracket. I have done hundreds of these and it is far faster and easier that way. The small piece of hose should be replaced with the, updated Volvo, steal and rubber coupling, though it is the molded O-ring seal that always leaks…
Seamus (sh'ay_mes)
98 V70R AWD-6, 540 ci (8.8L) 345hp Christen Eagle biplane, Cessna 180, 93 Ducati 750ss (my little sweety!), 98 VFR 800, XR 600,
#8 MrWinkey
MrWinkey
  • 4,759 posts
Posted 13 October 2006 - 11:41 PM
Actuall on the 80 series...I break off the trap mounting tab behind the accessory bracket then gind a very slight chamfer on the bracket allowing the use of 1/4" 10mm swivel socket when installing the new trap ..... it works quite well wink.gif
#9 Seamus
Seamus
  • 347 posts
Posted 15 October 2006 - 10:28 PM
I know that works but you have to remove the intake. If you only remove the bracket you have to do none of that.. wink.gif
Seamus (sh'ay_mes)
#10 smokin' T5M
smokin' T5M
  • 936 posts
Posted 18 October 2006 - 02:24 AM
here's an idea. Let's stop the pi$$ing contest and find out year and model. To some the bracket might be easier. I have done millions as well takes me about 2 hrs after cleaning the etm and banjo fitting with a new hose. I take off the manifold. Was interested to hear about the Aux bracket. Might try that next time. Have fun.
