V70's Series Of Problems
8 replies to this topic
#1 V70TSE
V70TSE
  • 37 posts
  • Interests:Volvos.... <br />Razzing pn my boat in the Carrick Roads!!<br />Computers!!!
Posted 06 October 2006 - 04:03 PM
I have been driving my '01 2.4T for over 2 years now, put 27k miles on the clock, all seems to be working fine, then suddenly, I get a message "NO OIL PRESSURE STOP ENGINE NOW" with the Oil light, no CEL so I stop, lift the bonnet, nothing, start again, absolutely fine, dont see the message for a while, then it flicks on again, now it keeps coming on and off for a few seconds, also once happened at startup.
Took it down to the dealership, before a 1,000 mile trip to drop my sister off at University, they say its fine, its justs some oil seals failing. Took it on the 1,000 mile trip, no problems, when i turn the engine off after leaving it ide for 5 minutes, theres a sharp clicking/buzzing sound for about 10 seconds, its coming from a module under the bonnet with 3 lines connected to it, the lines seem to be leading back to the turbo, and one to the manifold. Does anyone know if this is abnormal, or if its going to cause any damage. I took it down to the dealership to have the oil seals replaced and asked them to check it over, they said there was nothing wrong with it, but im not conviced. Any help is appreciated
Ruan
Edited by V70TSE, 06 October 2006 - 04:10 PM.
V70 2.4 T SE Moondust Metallic
Stock.. At the moment
[X] K&N Air filter [ ] Boost increasement [ ] Boost Gauge [ ] New Rims [ ] Big Brake Upgrade [ ] Lowered Suspension
IPB ImageIPB Image
IPB ImageIPB Image
#2 gr8hookup
gr8hookup
  • 15 posts
Posted 06 October 2006 - 04:19 PM
if it's a clicking sound and you have no oil pressure, try resealing the oil pan. sometimes the seals on the inside go bad
#3 ViperVette
ViperVette
  • 4,381 posts
  • Interests:Anything fast enough to do something stupid in... Cars/Girls/Boats...
Posted 06 October 2006 - 04:26 PM
that thing w/ the 3 lines coming out is the PCV system. I don't think that is a good thing for that to be making noise. It is supposed to be a vacuum system. So there shouln't be much if anything in there.
Tom
01' 72T5M
Oooo, thats nice.
HRE 19's Sonic Blue
06' M3 Competition Pkg
#4 V70TSE
V70TSE
  • 37 posts
Posted 06 October 2006 - 05:45 PM
Hmm, this is what i thought, as the Oil seals have now been replaced, I dont think thats a problem, but the clicking has got me worried.
Ruan
IPB ImageIPB Image
IPB ImageIPB Image
#5 smokin' T5M
smokin' T5M
  • 936 posts
Posted 07 October 2006 - 02:43 AM
On your motor the clicking noise could be the ETM. The PCV would never make such a noise even if it were bad. The way you are describing things it sounds like the turbo control valve could be making the noise. Has the car been hesitating on heavy acceleration?
Edited by Smokin' 855, 07 October 2006 - 02:51 AM.
#6 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 07 October 2006 - 05:05 PM
QUOTE(V70TSE @ Oct 6 2006, 09:03 AM) View Post
this happened to us on an 02 S80.... we ended up replacing all the rod bearings..
#7 V70TSE
V70TSE
  • 37 posts
Posted 07 October 2006 - 06:23 PM
As in Hesitation, you mean lag, its got AWFUL lag im pretty sure its the TCV, thats what i thought it was originally, its a chattering sound and its so bad, it shakes the solenoid off its mounts nad it just hangs about in the engine bay. This is getting worse and worse, Replacing the Rod Bearings is not gonna be nice to the bank!
The turbo lag is actually so bad, its almost as if when you mash your foot on it, the throttle valve takes a while to open, then it goes, not usual Turbo lag, where the engine pushes more, then it gradually winds up to giving full power, now its mash the throttle, nothing, then it all comes in one massive lump.
Any more ideas?
Ruan
IPB ImageIPB Image
IPB ImageIPB Image
#8 V70TSE
V70TSE
  • 37 posts
Posted 10 October 2006 - 02:30 PM
Bump? Anyone?
Ruan
IPB ImageIPB Image
IPB ImageIPB Image
#9 the underlørd
the underlørd
    Pretty Boy Racing
  • 20,462 posts
Posted 10 October 2006 - 06:04 PM
QUOTE(V70TSE @ Oct 10 2006, 07:30 AM) View Post
Bump? Anyone?
Ruan
the Oil message light has nothing to do with any turbo problems.
have you replaced the TCV/BCS?
