Strut Mounts For Upgrade?
Started by jl2, Oct 09 2006 05:17 PM
14 replies to this topic
Posted 09 October 2006 - 05:17 PM
I'm going to be upgrading to Bilstein HDs soon. I know that spring seats need to be changed, but I've heard suggestion re: strut mounts. Do they or do they not need to be changed on an 03 S80, with about 55k? I'll be changing the strut mount bolts and nuts too. Anything else that I need to change? Do the rear shock mounts need changing? Thanks.
2003 S80, Non Turbo
Posted 09 October 2006 - 06:14 PM
Never worked on an S80 but here's my experience:
'97 850 with 75k mi needed new strut mount bushings bad(spring seats). The mounts/bearings were ok.
'99 S70 with 104k mi needed new mounts/bearings worse than the bushings. Ended up replacing both while I was that far in.
The mounts might be ok with that many years/milage, but remember you'll be taking the whole thing apart again if they fail. New struts would probably put extra pressure on them.
Strut mount bushings = $20ea. Strut Mounts/bearings/plate = $50ea. Remember you'll have to replace all the bolts/nuts later if you have to go back. Decide if its worth the ~$80 savings to you.
'99 BMW 540i - 110k
'99 Volvo S70 AWD - 150k - Wife's
'93 940 - 220k+ - The Beast
'90 740t - 240k - gone
'97 850 T-5 - RIP 09/16/04 99,983mi
Posted 09 October 2006 - 06:51 PM
Replace the spring seats and call it done! As stated the new shocks will cause an earlier failure.
Seamus (sh'ay_mes)
98 V70R AWD-6, 540 ci (8.8L) 345hp Christen Eagle biplane, Cessna 180, 93 Ducati 750ss (my little sweety!), 98 VFR 800, XR 600,
Posted 09 October 2006 - 08:00 PM
I've replaced my Bilsteins HDs after being bounced around for 4 years....the ride got so harsh...wife would not get in the car.
Installed the Foni FSDs with 52k on the clock...surprised to see both spring seats were bad...rubber separates from the metal collar.
2000 C70 LPT ragtop
TME 3in down pipe, Supersprint cat back,16T with UPsolute chip @ 15 lbs of boost, k&n panel, Aquamist, boost guage
Eibach springs, Koni FSDs, IPD sways, QBM end links, strut brace, Euro jewel headlights with 6000k HID kit
Posted 09 October 2006 - 09:02 PM
Yeah, I almost said the same thing (but didn't want to get into which shocks are the best argument).
Had them on the rear of my 850, and the wife basically said "never again." There's a reason the BMW got new Koni's on all 4 corners and not HDs despite the extra cost. Didn't even have to plead my case on that one.
'99 BMW 540i - 110k
Posted 09 October 2006 - 10:04 PM
OK, I get it, although I've heard Bilsteins are "the best," too. I'm not interested in doing the cut-a-strut thing. What's the consensus, then for strut/shock replacement? KYB's? Monroe? Another sport-type strut Im not aware of?
2003 S80, Non Turbo
Posted 09 October 2006 - 10:07 PM
Koni Yellows are the best macpherson shock that i've seen for Volvo's.
Posted 09 October 2006 - 10:56 PM
Since I'm not planning on using lowering springs, is there any other difference?
actually the FSD's are one sale from ipd right now.
http://ipdusa.com/ProductsCat.aspx?Categor...&RootID=629
Posted 09 October 2006 - 11:02 PM
Thanks for the link. Should the rear mounts be changed too?
2003 S80, Non Turbo
#14
Posted 09 October 2006 - 11:08 PM
not sure the idiosynchrasies with the S80, but the front mounts usually are the only ones that seem to go bad with any frequency.
This topic is locked
