S60 T5 Noise And Vibration
Started by olegb, Oct 10 2006 05:58 PM
9 replies to this topic
Posted 10 October 2006 - 05:58 PM
Hi everybody, greetings from Pennsylvania, USA!
I’m driving 2002 S60 T5. Currently it has 33000 miles.
No major problems so far, however around 30K of mileage a pretty loud low frequency irritating noise and vibration appeared when the engine runs in the idle mode (700-800 RPM). When you turn the wheels the tone is changing for a couple of sec, (sounds softer), and then getting back to the previous condition. Has anybody heard or experienced the similar problem? What can be the source of it?
Thank you very much for any kind of info,
Regards,
OB
Regards,
OB
Posted 10 October 2006 - 06:04 PM
upper motor mount. super common.
Posted 11 October 2006 - 03:17 PM
Replace the mount. Just replaced the same thing on my dads s60 t5. Ipd makes a great replacement that is much better design and quality than the oem mount. Super easy to replace as well.
http://ipdusa.com/ProductsCat.aspx?Categor...&RootID=629
1999 V70R AWD FWD - Laser Blue - IPD polys, SharpHIDs, Eggcrate, TKI Endlinks, Marshall Instruments LED boost gauge, SNABB Pipe, Stylin Intercooler Hoses
2001 Volvo S40 1.9T - heavily modded 250hp 300ftlb - SOLD and missed often.
Posted 11 October 2006 - 04:11 PM
After replacing, you'll more than likely still notice a rough vibration at idle that smooths out when you press the accelerator. The IPD version is quite stiff and transmits vibration more than the stock unit. Consider this too.
Edited by elfnmagik, 11 October 2006 - 04:11 PM.
'97 850
Posted 11 October 2006 - 04:34 PM
Guys, thank you all very much!
I'm armed very well now!
(Have appointment with Volvo tomorrow, will see what they gonna say!)
Will keep everybody posted!
Regards,
OB
#7 Guest_arob_*
Posted 13 October 2006 - 06:22 PM
Still under warranty? That would be nice.
Chris
05 BMW 525
03 Acura MDX
94 Porsche 968 Cab
98 Volvo S70 T5 - Sold
05 BMW 525
03 Acura MDX
94 Porsche 968 Cab
Posted 13 October 2006 - 06:50 PM
The Volvo replacement mount is much better than the IPD mount. The "improved" mount is only under compression loads and has no fragile web to tear away. You can recognize this mount from it’s squared profile of the bushing. The IPD bushing has a major problem in that the aluminum bracket transfers far too much heat to the bushing causing it to rot away in a short time as well as vibration issues. I highly recommend the IPD bushing in the –98 cars though! Your vibration problem sounds like a right side (lower) engine mount.
Seamus (sh'ay_mes)
98 V70R AWD-6, 540 ci (8.8L) 345hp Christen Eagle biplane, Cessna 180, 93 Ducati 750ss (my little sweety!), 98 VFR 800, XR 600,
This topic is locked
