Deuss
Plz Help Asap. Tie Rod Wont Come Out From Wheel Hub Assebly Arm?
I dont know what to do. Im replacing my whole new front suspension so i took everyting off except for the tie rod end i cant get it out from the place where it connect with the bolt to the wheel hub assembly.... i took the nut off but why doesnt it come out???? plz help i need to get this done asap.
Hi
I needed a ball joint seperator, very easy to use then the tie-rod end came off in two parts. The rod part that comes off the rack and the knuckle bit that is bolted to the hub.
Hope this helps
matt
well i did rent that thing and i used it and used it and used it, then i smack it and smack it and smack it..... and no progresssssss... so i got a power saw and cut the thing off took it to the vice grip clamp it in... and smacked it with the hammer and it came out.... now i cant put in the new one.... im going to the store to buy a drill bit to bore the hole out... a little wooho....
WTF! :o
you most likey mangled the tapered hole in the spindle. I don't know what to tell you except stay the hell away from it with a drill bit! If the tapered stud on the tie rod end doesn't fit snugly into its mating hole in the spindle, you will have to replace your spindle. Nice going <_<
WTF! :o
Yeah, I'd probably stay away from it with a drill...I just beat the tar out of mine until it come free. Note: there was a LOT of tar to beat out...I was exhausted. Good luck.
