MarkNJ
Noise Coming From Driver's Doorsill / Window Area
Sounds like a crackling / rattling, like air is leaking in maybe? Not loud enough to hear with the radio on and it only happens when I'm up to highway speeds. Stops again when I slow back down below 40 mph. Just wondering if this is something others have experienced and if there was an easy way to take care of it.
Yeah, that was the first thing I thought of, but putting my hand on the speaker doesn't change the sound at all. Seems like it's coming either from the window area itself or just inside the window, like around either the door seal or the doorsill.
If you remove the door panel there are a few small plastic clips that are glued to the upper inside part of the door panel. These clips fall off and can make some noise. Glue them back on with a good gorilla snot..
Sweet ride by the way!! ;)
