Cv Boot Kit
Posted 22 December 2006 - 12:28 AM
Posted 22 December 2006 - 01:23 AM
2000 Mercedes W210
1996 855R
1995 854 NA Auto
RIP - Dad - M.G.T 10/31/42 - 12/03/05 "Press On"
Posted 22 December 2006 - 01:44 AM
Guest_Guest_*
Posted 22 December 2006 - 01:49 AM
Posted 22 December 2006 - 03:04 AM
I agree...don't bother with a CV boot kit...it's 2/5 hours of labor you'll have to pay for, or more.
Buy an axle and be done with it...30mins labor- tops.
I got my axle from www.raxles.com (you'll have to call them- talk to Marty).
'91 240 Sedan- Sold 4/21/09
Posted 22 December 2006 - 03:35 AM
The inner is made out of the same material and yes sees less road abuse (sand, rocks e/t/c) but will still be nears its shelf life
In addition to the wear on the actual axel parts
Posted 22 December 2006 - 05:11 AM
I recall raxles.com mentioned here several times so they must be good but I also recall reading that they are rebuilt and cost more than the new EMPIs at the above Eeuroparts link. AutohauzAZ has the EMPI for even less. Anyone use EMPI axles? What about DSS axles? FCP now carries this brand for $119 new without core charge, supposedly exceeds OEM specs:
http://fcpgroton.com...htm#rearbearing
Thanks!
Edited by Geevs, 22 December 2006 - 05:23 AM.
Posted 22 December 2006 - 05:25 AM
Posted 22 December 2006 - 05:28 AM
OK, good advise. Now to decide whether it's EMPI or Raxle.
Posted 22 December 2006 - 06:19 AM
This is an easy job to do, it just takes some penetrating oil to get the ball point out from the hub, then two 12mm bolts to take the carrier off and its free. probably an hour job on the ground if the ball joint isnt to stuck. i believe its a 30mm to take axle off the hub, haha i just did it today but i cant remember the numbers. Anyway with a little bit of your time you should be perfectly fine doing it yourself.
Posted 22 December 2006 - 06:24 AM
Posted 22 December 2006 - 06:38 AM
haha i didnt even notice the name, i was just shooting the stuff on here. anyway nope the last time i did the CV joints was my 5spd swap. I work around the CV joints almost every other day on other cars besides mine, getting that control arm free is a PITA, thats why MAC tools invented a special pry bar:)
P.S. I dont even need the white injectors at the moment, but who can pass them up for free right?
Edited by binglax09, 22 December 2006 - 06:39 AM.
#14
Posted 22 December 2006 - 07:21 AM
be careful with that ball joint though, if you mushroom it you will be breaking out a hacksaw and a file... Pickle fork anyone? PB blaster is your friend for this job, a lot of it.
#15
Posted 23 December 2006 - 05:57 PM
98 White V70 AWD, TME Springs, Koni Yellow Fronts, OMP Front Strut, Volvo Dual Exhaust, IPD ECU, MBC at 10 psi, 17" rims ... RIP
98 Black V70R AWD, K&N, Eurosport Dual Exhaust, Bilstein Fronts, Rear lowered by drop bolts,
09 Suzuki Gladius 650cc
#16
Posted 23 December 2006 - 06:25 PM
181,000 miles
#17
Posted 23 December 2006 - 06:27 PM
1972 GMC Jimmy
2012 HD Night Rod Special
#18
Posted 23 December 2006 - 06:28 PM
181,000 miles
#19
Posted 23 December 2006 - 07:18 PM
#20
Guest_Guest_*
Posted 23 December 2006 - 08:43 PM
Theres several companies that now sell these brand new and not rebuilt from $110 or so. another company is through Parts America for $120 with a Lifetime Gaurantee and you can even pick them up in the store. Parts America.
If you are going to do the repair yourself the only way to go like the others said is with a new axle. You get everything brand new with the 2 boots already installed. A no brainer really.
