you can't use OEM type or can you, in a bind, gotta get them replaced, the Akebono's went w/o a warning and are chewing on rotor in a bad way, new ones on order but need brakes ASAP until my SUV gets fixed, thanks !!!!
Brake Pads Types
Started by Boosted5cyl, Dec 27 2006 03:03 PM
Posted 27 December 2006 - 03:03 PM
98 V70 R - AWD SOLD & currently dead sadly...
019 - Black on black leather/suede
X-drilled Zimms-Akebono ACTs-EST intake-IPDstrut brace-SAMCOs 4 intercooler-VDO psi gauge, Custom 3in DP & exhaust w/dual Borla XR1-s
RICA tuned~Super60~AEM Uego~TMEs and IPD sway install pending ~
Posted 27 December 2006 - 03:17 PM
I used OEM
Posted 27 December 2006 - 03:18 PM
organic or semi-metallic, shouldn't matter right ? thnx for the reply man
Posted 27 December 2006 - 05:03 PM
BUMP,,,,,,,,,,,,,,,,,
is there any pads NOT to use ???
This topic is locked
