ACES70
P1550 Code
ACES70    7
I recently got a check engine light. Its P1550 "manufacturer controlled speed metering" or something close to that. Any ideas as to what might casue this? I just got some new rims and tires and I was thinking that maybe the larger size would throw off the speedometer. Could this be the case or is it something else?
Chilled man    2,979
whacky024.gif lol
that would more then likely be the speed sensor on the transmission , if you change tires the car has no way of knowing , if I remeber correct you speed is told to you off the revolutions on the transmission and more then likley that sensor , its on the top of the transmission and is pretty easy to change , not 100% sure of location although
Guest Guest_Chilled Man_*
is the abs light on?
you dont have a speed sensor for the speedo on the transmission!
hmm then how does that work I always thought there was one ?
garbergtsi    1
vehicle speed is aquired through the ABS module by averaging the front 2 wheel speeds, then sent to the network to the ECM, instrument cluster, ect
Chilled man    2,979
uh duh why didnt I think of that :blink:
so instead of the sensor being bad off the transmission it would be the sensor of the wheels?
ahh heres a great link :)
http://volvospeed.com/vs_forum/index.php?s...c=68789&hl=
Piglet    60
I've got the same code +ABS light so if you figure this out, it'd be great ;)
ACES70    7
My ABS light was on for a little while but then it went off. I got the code read and erased it and It hasnt come on yet, I drove it about 55 miles so far.
Chilled man    2,979
that link is a horrible link because of
a) its concerning a 95
B ) already on the second post, there is bad information.
doh ok I am done posting on this thread since I cant seem to read it right ouch
hmm must be :blink: tongiht <_<
ACES70    7
whacky024.gif lol
Lol<- PWNED
garbergtsi    1
basically the code means the ABS module either lost communication or there is a fault in either front WSS's.
You need to get a scantool to access the ABS to really diagnose it.
or just guess and say its the ABS module like everyone else does
ACES70    7
Well I havent had any more trouble out of it, and if it is the ABS module I have two extras sitting around.
Chilled man    2,979
Lol<- PWNED
yeah who the hell knows what I was saying :(
I should be posting that newbie smiles formyself on that one ;)
Piglet    60
Make sure your speed sensors are seated right. If you put on new wheels there's the possibility you could've hit the wire to a sensor. There's nothing like having your speedo cut out while driving home and having to drive past a police station
