Edited by necvolvo, 30 January 2007 - 01:56 PM.
Intermitant Ets Light
Started by necvolvo, Jan 30 2007 01:51 PM
Posted 30 January 2007 - 01:51 PM
99 V70XC turbo wagon 85Kmiles. ETS light comes an goes about every third or forth drive cycle. Dealer did ECM903F upgrade for the second time and also noted a ECM904D mismatched hardware code which he didin't have a clue about. My question is; could this throw the ETS light and why did it arise (possibly ABS computer replacement?) Also ETM looks to be original but I do not think the dealer wants to replace it for some reason. HELP!
Posted 31 January 2007 - 12:47 AM
It probably needs an ETS
"SMOKE TROUT NOT CRACK"
Posted 02 February 2007 - 03:23 AM
if it has a white sticker, you are due for a new free one with yellow sticker
take it somewhere else where they know this and can give you a straight answer, and the proper check of the PCV system at the same time all based on the warranty.
1995 850 glt rattling down the road at 157K
99 V70XC 120K
99 V70XC 120K
Posted 04 February 2007 - 06:30 PM
Look at the fuse box under the hood by the l/f strut tower. Open the cover and look at the eyelet brace with a flashlight. Look down the eyelet bracket and see if the copper wires are black and corroded. That could be you problem if this is the case.
This topic is locked
